Clutch Failure
word302
Oregon
JLU
Placebo?? lol, It's very simple to understand. When you shift the rpms rise anywhere from 1 to 2 thousand rpms in between shifts NOW the rev's drop as I shift instead of rising! How is that placebo?? This happened after I had the recall done.
Because the recall absolutely does not affect rev hang. I still have it just like it was before the flash. Rev hang does not increase the RPM between shifts, it holds it, which is why it’s called rev hang not rev increase.
m3reno
Sal
caldwell
2022 Jeep Wrangler JLU
I guess we are all imagining it then! How do you know it doesn't affect the rev hang?
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
Because that’s not why or what the software was written for.
That doesn't mean they can't include other changes in the update.
Ahre
Paul
Livermore, CA
2020 JLUR, Ordered Mar 14, 2020
Get the recall done. I had the recall done and it does NOT detune the engine but does make the rev hang a lot less noticeable. I stated this in another thread that in my opinion when the rpm's rise when shifting (rev hang) I'm sure it overheats the clutch. My 2022 barely has any rev hang.
The Recall will ONLY Detune the engine when an Over Heat Condition occurs.
QwikKotaTx
Houston, TX
2015 Hemi Ram, 2002 Porsche 911 Turbo
I think you'll be good.
The recall is supposed to prevent overheating the clutch...I don't think it would have prevented your issue.
The recall is about pressure plate fracturing. Looks like that is exactly what happened here.
QwikKotaTx
Houston, TX
Guys what years
What year JL's are being recalled? I looked up 2022 recalls and didn't see anything
I would check it again. Ours is on there. I want to say it's all JLU's.
It's all BS. There is no temp sensor for the clutch or bellhousing area. It's some algorithm that compares RPM to wheel speed over time.
