Toycrusher
Confirming what Maverick had to say.Half doors might be second favorite thing in the world. Forgot what the first was...
Affirmative, I am on the OEM KO2's.
Gearing multiplies the force of the engine. 3.45s were an absolutely ridiculous decision by Jeep. I imagine 4.88s are perfect with stock size tires. I'm on 37s and planning to go 5.13 or 5.33 to get a similar effective ratio to what you are enjoying right now.
The Centerforce high-mass flywheel has a big advantage over the stock featherweight flywheel when it comes to getting your Jeep moving. In the simplest terms, it takes more fuel for your engine to start spinning, but that extra energy put in is retained within the flywheel. when you let out the clutch abruptly, that energy is transferred to the wheels getting you moving without requiring you to add fuel through additional throttle or to waste energy through excessive clutch slippage.
Why didn't Jeep use a heavy flywheel to start?
Because Govt mandated start/stop system, and a heavy flywheel wastes fuel when using start/stop...
