Cheap diy dual battery setup
TabarnaCarl
Canada
2 doors JL m6
Hi
I just brought a 12v cooler. I already had a small bluetti eb3a, but it's kinda not enough to power the cooler for 12 hours.
I'm looking to do a cheap diy dual battery setup. I have a 2 doors and I do "OvErLaNd" stuff, so space is important. I found a deep cycle battery that will fit in the aux battery location (aux battery already deleted)
-Cooler is a bodega 40quart, 60 watts 5amp
-Deep cycle battery I've found to fit in the aux battery location is 30ah
Other than a smart battery isolator and couple inline fuse, what would I need ?
I've read I might need a DC to DC charger ?
Anything else I should know with our "smart alternator" ?
THAW
Foster
23 JL4DrRubicon
A battery isolator won't charge a deep cycle AGM battery optimally, causing shorter battery life. A DC-DC charger is a better solution, but it's typically more expensive and has a slightly larger footprint. A DC-DC charger is required if the second battery is lithium-ion.
Which 30Ah battery fits in the AUX (ESS) battery box? FYI, 30Ah is less than your BLUETTI, which is about 37Ah.
rcitone
Wen
Washington
2022 JLUR XR
Similar use case. I bought a LifePo4 battery and a cheap Amazon DC-DC charger (15v 5A constant output). The charger is controlled by a switch. I monitor the Voltage of the battery manually to determine when to turn on charger.
TabarnaCarl
TabarnaCarl
Canada
2 doors JL m6
@TabarnaCarl, I read the wrong BLUETTI spec; your power station is about 22Ah, so a 30Ah battery does have a meaningfully higher capacity.
Where did you found that ? I couldn't found any info on the ah of my eb3a even in the bluetti website
TabarnaCarl
TabarnaCarl
Canada
2 doors JL m6
https://a.co/d/856HnHo
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
That's a LiFePO4 battery, so you should definitely use a DC-DC charger.
I was going to question why someone that's concerned about space and capacity would be looking at an AGM battery. It's good to know a LiFePO4 (possibly?) fits in that small space!
THAW
Foster
23 JL4DrRubicon
I don't have the inside dimensions of the AUX (ESS) battery box handy, but the AUX14 battery standard is 5.9" L x 3.4" W x 5.7" H whereas the linked 30Ah LiFePO4 battery is 7.2" L x 3.3" W x 6.9" H.
If the 30Ah LiFePO4 doesn't fit in the factory enclosure, there's likely room to strap the battery in the AUX (ESS) battery location without the box (though for safety sake, it might be wise to protect it in some way from potential puncture damage).
Also, I would expect the 30Ah LiFePO4 battery to degrade faster than average due to engine bay heat.
TabarnaCarl
TabarnaCarl
Canada
2 doors JL m6
Well the factory aux battery wasn't strap at all....
Ratbert
PNW
Software Engineer
Those batteries typically have 2 to 5k cycles in them. Degrading one that's only used when overlanding would most likely never be noticed.
THAW
Foster
23 JL4DrRubicon
I measured the inside of my AUX (ESS) battery box at about 6 and-a-quarter inches "long", 3 and-a-half inches "wide", and 6 and-a-half inches high. So, I'm skeptical the Amazon 30Ah LiFePO4 battery will fit it. But in this case, I'd be happy to be proven wrong!
TabarnaCarl
TabarnaCarl
Canada
2 doors JL m6
I didn't measure the aux battery box, but I measured my aux battery and dimensions are 5 3/4 x 5 5/8 x 3 3/8...
Been 2-3 years since I did the aux battery delete but I think the battery was a little loose in the box...
Thanks for your info, I might try to find another battery or I'll find a way to make it fit
