Can anyone help me?
D.R.Davis
Don
Indianapoils
Wrangler JL
I think I screwed my jeep up. I had it re-geared to 488 gears I run 35 inch
Nitto Ridge grappler the people who re-geared it had me use Flashcal F5 to tune it. I have reset it multiple times and I either have very aggressive down shifts or I can’t even hit eighth gear. I have a 4 inch lift I have no idea what to do
Gorpf
‘21-392, AEV-JL370
Retired/Caregiver
I’d suggest getting 37-38” tires with the 4.88 gearing. Also, take it back to the shop that did the work or to another gear shop anf get their input.
jadmt
jeff
montana
use this calculator to see if your rpms are matching what they should..make sure you are imputing the correct numbers in for tire size and gear ratios. tire size will not be what is printed on them but actual size. your 35's are actually probably closer to 33.5-33.75
https://metalcloak.com/gear-ratio-calculator
Oletimer
Darrell
Crystal River, Florida
23 ram 1500 5.7 , 24 392 final edition , 24 F150 5.0
Logging Contractor
am I understanding you correctly, it wont pull 8 th gear ?
something is definitely wrong. I had 4.88s with 35s on my last jeep.
there was zero issues with pulling hi gear.
makes me wonder , do you really have 4.88s or did the shop put in something else by mistake.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
What do you mean by or? It varies??? Based on changes to FlashCal or something else?
D.R.Davis
Don
Indianapoils
Wrangler JL
I have measured them the tires to be 34 inches horizontally and still I have the same issue. Do you think that I may have selected the wrong gear ratio for my tires? Maybe I should’ve went with 456 instead of 488
yes, it seems like every time I reset it back to stock and then re-enter the information it relearns a different way like almost every time
D.R.Davis
Don
Indianapoils
Wrangler JL
When I reset it, I tried to clear all the memory in the jeeps computer and re-enter Flashcal information the same as I did all the times before and still it relearns differently . one time I was able to get all gears, but the down shifts were so aggressive that it would push me forward as I was slowing down and that can’t be right
D.R.Davis
Don
Indianapoils
Wrangler JL
I have even been on the phone with super chips to update the Flashcal like 2weeks ago
Nokones
Kenny
Sun City West, AZ
23 Rubi, 21 Silverado, 13 Grand Sport, Cayman GTS,
Unemployed For The Rest Of My Life from a career of spreading love, cheer, and joy to lots of special individuals that were asking for attention..
There is a power train formula that Mopar uses to determine the proper gear sets for your Jeep year and model with the various tire sizes. If my memory serves me right, running with 35s, 4.56 gear set was the most appropriate gear set to run with a 23 Wrangler 3.6L e-Torque Automatic. My Wrangler factory gear set is 4.10 so the 4.56s are not much of a change so I did not change my gears when I went to 35s.
I believe someone posted that power train formula on this forum a couple years ago.
yokramer
Snark Incarnate
Have you gone back to the shop that did the work and have them you know fix what they did?
Oletimer
Darrell
Logging Contractor
4.56 or 4.88, either way it should not be a issue.
4.88s are fine . i would think its either a flashing problem or I would bet you dont have 4.88s for whatever reason.
6.2Blazer
Ohio
2019 JL Sport
There's simply not a huge difference between 4.56 and 4.88. Most people would not be able to tell the difference by seat of pants feel between the two. Did you notice any of these issues before you changed parameters with the Flashpaq? Did you actually drive it after the gear swap and before changing the parameters? Really sounds like some sort of programming issues.
D.R.Davis
Don
Indianapoils
Wrangler JL
Thanks guys for all your input. The shop that did the regear has said that the flash did not take for some reason. So I will be getting a new tuner.
MntGoat
Doug
TN
2022 Rubicon
Machinist
Why a tuner? What year and engine.
Not going into 8th is definitely a controller issue.
