ASSFROW
- Gary
- Jul 7, 2024
- Mt. Airy, MD
- 2024 Rubi X
I saw your write up on the bumps, I was the one that derped on the bump stop lengths. What shocks are you running?Your original stated goal was good road driving, no lift, increased uptravel, max 35" tires, and snow and mild off-roading capability.
The XR package comes factory with a 1.5" lift. Add a half-inch spacer and you're at 2 inches lift. Plenty of room for your 35" tires. Add the simple to install IRO hydraulic 2" bumpstops and you'll not only increase uptravel, you'll probably bottom out your shocks before you max out your bumpstop.
https://www.jlwranglerforums.com/forum/threads/hydraulic-bumpstop-install-and-impressions.166126/
Edit: Found your shocks.
How much more could you have gone up if the shocks didn't stop you?
