ArmyRN
- Paul
- Dec 21, 2022
- Longview, WA
- 1946 Willys CJ2A, 1998 Jeep TJ, 2023 Willys JLU
23 JLU XR Willys 2.0T. Original BFG 35" tires. Clayton 2.5" springs rear, factory XR springs up front with a TF 1/2" spacer (so 2" lift total up front). Fox 2.0 IFP shocks for a 2 - 3" lift. That gave me 1.75" of space before the front bumpstop made contact. I wanted more (the XR bumpstops are about 1.375 to 1.5" longer than non XR Jeeps).
Iron Rock Offroad (IRO) sells a 2" hydraulic bumpstop kit. Fairly easy install (gotta cut factory bumpstop tubes, so no going back). There's an install video in the link. Pretty straightforward install.
https://www.ironrockoffroad.com/product/trail-tamer-20-hydro-bump-kit.html
IRO also sells a tool to tighten the rings on the assembly. I'd recommend purchasing it if you decide to purchase this bumpstop.
So I took one for the team today. I hope this helps other XR owners.
Installed it today. Essentially drop axle, pull springs, cut tube, install hydraulic bumpstops, put back together.
After install, now I have 3" clearance before making bumpstop contact, plus add the 2" for the hydraulic bumpstop compression.
All good right? Kinda.
I put a tire on, connected the shock, no spring, swaybar still disconnected, track bar connected, and cycled the suspension (only did driver's side, passenger side was left hanging). Tire (factory BFG 315.70.17) was tucked in and made contact with fenderwell with 1" left to go of bumpstop compression, and shock was getting close to full compression. In real life would I ever get it this twisted? Probably not, but technically I guess it is possible based on my suspension cycling. And yes, in the picture below the bumpstop is making contact and has compressed about an inch.
Then I put it all back together. I ordered a 1.25" front bumpstop extension to address this (should be here next week) so I'll drive it easy till then. I don't really fourwheel this Jeep. I debated a 1" bumpstop extension, but thought an additional .25" would add a small margin of safety.
https://www.extremeterrain.com/clay...ont-bump-stops-125-inch-tall-cor-1409101.html
So when I put in the bumpstop extension, I'll kinda be back where I started (about 1.75" before bumpstop makes contact), but after that I'll have another 2" of progressive compression with the hydraulic bumpstop. Not huge, but double from what I had before adding the hydraulic bumps.
Someday I'll get a winch and bumper, and will get rid of the front factory XR springs and spacer, and put in Clayton 2.5" Overland springs up front. We'll see if the added weight up front but taller stiffer springs cancel each other height wise (and corresponding bumpstop space).
