Zandcwhite
- Zach
- Sep 4, 2019
- Patterson, ca
- 2019 jlur
It's easy if you can stick weld. Connect the + of 1 battery to the negative of another. Use the - of the 1st battery as the ground, connecting 1 jumper cable from it to the metal you want to weld. Take the positive from the 2nd battery and use that jumper cable as your rod holder. Now strike an arc like any other welding rod and burn away. A pair of welding goggles and some rods don't take up much space. If you forgot the goggles you can stack 3-4 pairs of sunglasses but you'll see spots for a few days.forget all these winch setup arguments. Teach me how to “trail weld”. Seriously.
