Blind spot alert is not working
2019unlimitedmoab
2019jeepmoab
Torrance, USA
2019 unlimited moab
Hey guys,
My blind spot alerts are not working suddenly! I installed winch and aftermarket front bumper a week ago and everything was working fine. And this morning I have this alert popped out from my dash screen. Is this issue related to winch wiring at all?
I have scheduled a visit to dealer this tuesday but I need your opinions before I take my baby in.
Jeep Wrangler JL Blind spot alert is not working 20190810_120027
californiajeeping
JLUR
Hey guys,
Check to make sure all fuses and relays are seated correctly. If that doesn't work, pull the fuse related to the blind spot system and put it back. Something similar happened to my backup camera and not only was the backup camera fuse loose, over half of the fuses and relays "snapped" in place when I pushed down on them.
turbosix
dallas
2019 JL Rubicon
Hey guys,
Are your doors on
robaw
Rob
Iowa
Are your doors on
If they are - could be that the wiring harness isn't fully connected. I think when that warning is on the triangles on the mirrors are supposed to stay solid. Are yours lit up @2019unlimitedmoab?
PS - shouldn't have anything to do with front winch install, sensors are in the taillights. But like @californiajeeping said, check your fuses.
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
Had this issue on a Jeep Compass I had and it took 7 trips to service to address hopefully your issue get resolved quicker
slamr
Upstate NY
2019 JLU MOAB, Harley SE Street Glide
Same problem. Same message. Fixed by removing and reattaching the door harness about a dozen times. No blind spot, remote start or mirror adjustment. The passenger door did not register in the dash as being open so I narrowed it down to that door. If you pull the fuse the message changes to needs service.
2019unlimitedmoab
2019unlimitedmoab
2019jeepmoab
Torrance, USA
2019 unlimited moab
Thank you so much guys!!
It turned out to be the Rugged Ridge's taillights bracket covers were interfering with sensors. Took them out, now they are working fine.
Thank you all for the comments.(I did push all fuses down to make sure they are seated in places correctly.)
californiajeeping
JLUR
I was about to order those tail light brackets. Now I'm not.
Drveovru
Corey
Fort Smith Arkansas
2018 jlu sport
I had the same issue , I ended up sliding the connector on the kick panel off its clip so I could check the pins for damage. , I had 2 pins that had slid over a little in the connector. I had to bend them slightly and it fixed everything.
HealthRebel
Jerry
Colleyville, TX
2020 JLRU Ocean Blue
Good point. I have heard that all fuses needed to be challenged and make sure they are in properly.
aldo98229
Aldo
Bellingham, WA
Market Research
Yeah, don't waste your money on those Rugged Ridge tail light "guards."
I got mine three years ago. The problem is the guards are made of aluminum but the bolts that come with the kit are steel. The aluminum reacts with the steel and over time become soldered together for good; I cannot remove the damn guard any more.
Rugged Ridge piece of crap!
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
I consistently deal with dissimilar metals when it comes to fasteners in my business. Always boils down to poor engineering.
Austin23
Austin, TX
2020 Jeep Wrangler Rubicon
Glad it was an easy fix. Those are the best kind.
