Better intake noise
Old Dogger
Bill
Cave Creek Arizona
Welcome to the Forum!
All three of ours, still have the stock air intake system.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
I was wondering if there was a way to improve intake noise without changing the stock filter. I want to keep the stock air box.
I know that for a JK, HPS has a silicone hose: https://www.extremeterrain.com/hps-jeep-wrangler-silicone-intake-hose-black-57-1639-blk.html
However, has anyone done anything to the JL?
Not sure you could use the stock filter, but this would do the trick: https://rippmods.com/products/2018-...9RrU9EJIafdNdbAd8qdNYrwk-iyE-ajuUUyGvky9jSXcg
EDIT: And it's 10% off for Labor day!
roaniecowpony
Retired Engineer
By "improve", do you mean increase? If so, you could replace the tube between the filter box and the throttle body, with a tube that doesn't have the Helmholtz chambers on it.
Since the Helmholtz chambers are on the bottom, you could use a hot knife and cut them off, then patch it with some of the plastic from the chambers, using "plastic welding" methods.
Mike_Hawk
Illinois
2022 GOBI JLUR 3.6
Mechanical Engineer
What difference does the silicon tube make on the JK?
petrograd
Chicago
2020 Rubicon
roaniecowpony
Retired Engineer
Thank you! Did you also replace the filter with the oil cotton gauze or did you retain the stock filter?
Do your engine a big favor, don't use an oiled gauze filter.
AZ Hella
Sonoran Desert
JLUR
I have 2 of the AFE dry filters, the "big" one that came with the kit and a standard size one. I just swap them out as needed for cleaning.
One thing to note if you have an aftermarket exhaust it will drown out almost all intake noise.
One of the biggest benefits of this kit in it really cleans up the engine compartment.
Jeep Wrangler JL Better intake noise engine3
Jeep Wrangler JL Better intake noise engine2
roaniecowpony
Retired Engineer
AZ Hella
Sonoran Desert
JLUR
There is no "baffling" in the OEM tube. It has Helmholtz chambers off to the side of the tube, which cancel resonant frequencies, but do not restrict flow.
Thank you for correcting me, at least you did know what I was talking about.
roaniecowpony
Retired Engineer
One thing to note about the OEM intake tube is the corrugated flex sections. Corrugations disturb the flow in a negative way, by effectively reducing the effective diameter of the flow path. So a smooth connector instead of those corrugated flex connectors is better.
roaniecowpony
Retired Engineer
While riding horses up a canyon full of broken rock near Springerville, a friend said "When God made Arizona, he forgot to give it dirt". He must have been right. You don't have any dirt in that engine compartment.
AZ Hella
Sonoran Desert
JLUR
LoL. Arizona is one of the dustiest places on earth, I'm just OCD about having a clean engine bay.
