Best dead pedal?
JL ME
JOHN
Portage Wi
2021 JL Willys ,2006 Roadking , 2008 Hayabusa
Industrial Maintenance
None.
Speed331
Sean
Las Vegas, NV
2008 Jetta, 2018 Discovery Sport, 2020 Wrangler Sport S (on order)
Quadratec is on back order. The reviews on the M.O.R.E. all seem to mention that it’s a royal PITA to install - for all the usual under dash access reasons. Some reviewers even recommend removing the drivers seat.
Edit: M.O.R.E. Is out of stock as well.
A simple piece of duct tape makes the install much easier. I'm 6'4" and had it installed in about 15 minutes.
The biggest drawback is it has three possible positions and has to be removed to change them. The short cut is to install in the middle setting - decide if it's 'too warm, too cold or just right' - that way, if you need to move it, you only have to do it once...
jludave
The Isle of Long
IT Manager
I had the M.O.R.E. dead pedal for about a year. Yes, it was a royal pain in the a$$ to install. I tried the various positions that it has, but never felt it was exactly right. I swapped it out for a Quadratec dead pedal and couldn't be happier. The Quadratec was simple to install and is set perfectly for my driving style.
TylerU
Tyler
Oklahoma
Rubicon JLU
J.M.O...skip it. The install was a b*tch for me and I hardly ever use it.
Mos.Jeep
Marty
Wisconsin
2021 Wtabgler Rubicon
I highly recommend NOT buying the MORE pedal. As other have said total PITA to install. It has 3 positions. If you use the middle position you cannot get rear bolt nut on so my pedal is mounted with only 1 nut. The mounting of the Quadratec pedal is MUCH more sensible.
813 Fabrication & Design
Rock Sponsor (Level 1)
Jeremy
Louisville, KY
2020 Jeep Gladiator / 2022 JLUXR
Take a look at the Dead Pedal I designed. Made from 1/8" aluminum, so it is beefy! Simple install, all you need to do is remove the firewall bolt, put the pedal in place and replace the bolt. The pedal lifts out of the way for floor mat removal. The best feature of the pedal... I have two optional switches that mount in the pedal. The "Old School" floor dimmer switch or a momentary switch. I use the floor dimmer switch in my JL and JT and have it controlling a set of off-road lights. It makes the ultimate backroad high beam switch. No more fumbling trying to find a button to push while driving, just click the switch with your foot. The momentary switch was an option I added for customers looking for a way to control items such as a train horn.
https://www.813fabrication.com/product-page/jeep-wrangler-jl-gladiator-jt-dead-pedal
Let me know if you have any questions!
Jeep Wrangler JL Best dead pedal? Jeep-JL-JT-Dead-Pedal-00
Jeep Wrangler JL Best dead pedal? Jeep-JL-JT-Dead-Pedal-01
Jeep Wrangler JL Best dead pedal? Jeep-JL-JT-Dead-Pedal-05
Jeep Wrangler JL Best dead pedal? Jeep-JL-JT-Dead-Pedal-08
Jeep Wrangler JL Best dead pedal? Jeep-JL-JT-Dead-Pedal-12-install
Jeep Wrangler JL Best dead pedal? Jeep-JL-JT-Dead-Pedal-13
Jeep Wrangler JL Best dead pedal? Jeep-JL-JT-Dead-Pedal-14
Terrymo
Terry
2023 JLURXR 3.6 ET
Another vote for the Quadratech with rubber pad. Super easy install. When I ordered, the pedal with pad combo showed out of stock, but still shipped within 2 days. Maybe call Quadratech to check inventory.
rcadden
Ricky
Asheville, NC
Marketing
If the rest are out of stock, check out the Hooke one on Amazon. 2 years now, it's great. Sturdy, and it lifts up just slightly to remove floor mats (not fully able to move out of the way, like some others). REALLY easy install.
Tncdrew
Tom
East Tennessee
2022 JL Willys, 3.6L - 8spd
If this had been available when I bought my QT pedal, I would've jumped on it!
This looks like an awesome design!
Jeremy at 813 offers some really cool Jeep accessories, and provides Top Quality customer support!
And the little "Artistic" surprise that comes with your order is precious ?
Support local US small companies!
Jeremy
Louisville, KY
Thank you! Much appreciated. I try to design parts that are useful, strong and have multi-purpose. If it's not something I would put in my Jeeps I won't design it! I also only make parts in aluminum or stainless steel. I will never use steel. I have purchased too many parts over the years that fail, some in less than a year. I can't bring myself to sell a customer a part that would do that!
DonBindas
Don
Naples, Florida
Ordered a 2020 JL Rubicon Unlimited in Bikini with Dark Saddle Leather on 7-8-19 and was delivered by Criswell 8-22-19
KBB Analyst
gl420
New York
2019 JL 2.0T
+1 for the Quadratec. Super easy install, multiple positions, and flips up to clean mats.
I ordered it when it was out of stock and it shipped within a week, this was last year.
au176
WNY
2021 Islander, 2020 Newmar Ventana, 2014 HD Road King
Tired again
+1 for the Quadratec pedal, with the optional rubber pad that matches the Jeep pedals. Quick, easy install, Stainless steel, and can be easily rotated up out of the way if necessary. The pad installs via double-sided tape, but it hasn't moved in 25,000 miles, so it's GOOD adhesive.
I don't know what the deal is with all these dead-pedals constantly being on back-order. I ordered mine back in 2021, and it took a couple months to get it. Weird...
