Battery Level Charging Low
FatBoy01
NY
2014 Wrangler Sahara; 2001 Harley FatBoy; 2018 Wrangler Rubicon JL (Ordered)
Retired @ 55
So I trickle charged the main battery and then using terminal N2 I fully charged the ESS smaller Battery..
Frank ....Please, post a pic of "N2" and provide more info on this N2, it's location.....
Rusty Teeth
York,PA 17408
2021 JL Sahara Altitude
Electronics Tech/ Fabricator/ 5G Fiber Optic Cellular Tech
Located on the PDF outputs. Power distribution and fuse box, in another post i had touching terminal see pix
Jeep Wrangler JL Battery Level Charging Low Screenshot_20180327-125634_Photo Editor
Jeep Wrangler JL Battery Level Charging Low Screenshot_20180327-125545_Photo Editor
Jeep Wrangler JL Battery Level Charging Low 20180323_102151
Rusty Teeth
York,PA 17408
Oh sorry, also every fuse and relay in fuse box distribution box was LOOSE every one clicked into fully seated position!
FatBoy01
NY
Retired @ 55
snipe:
. So I trickle charged the main battery and then using terminal N2 I fully charged the ESS smaller Battery.. I
Saw your pics. Thanks!
So you took positive cable of trickle charger and hooked it to N2 and then connected other trickle charger connector to .... ?
I learned long ago when I took delivery of a new vehicle to always go to the power distribution center / fuses and to push firmly down on each to insure they were seated properly.
Rusty Teeth
York,PA 17408
I was getting 2 diff voltages on N1 and N2
According to the fusebox lid shows one going to the ESS stop start battery.
So i charged both, using same battery negative as it uses chassis ground also.
Took many hours to charge that also...
If N2 voltage gets too low you see this dreaded screen on center dash. You will need a tow at that point
and better learn how to get it outta park manually! No power, will not allow you to get to neutral.
Jeep Wrangler JL Battery Level Charging Low Screenshot_20180404-152046_Gallery
crik
Dallas
2017 Renegade; 2018 JLUS
Thanks for pointing this out, Frank. I just checked my fuse box and found the same thing--every fuse/relay needed to be seated.
Rusty Teeth
York,PA 17408
Yes! When i met BAM, we looked at his jlu rubi, same thing all loose and relays......
Medtown
Medtown
Atlanta
Jeep JL Rubicon; Granite/Tan
Whats update, hear anything?
s
Sorry, I was off the board for awhile..no issues with my JL since they replaced the
Thanks for posting....Looks like i will have to go back and reseat all of mine after seeing your post. Since the dealership replaced my relay, and now about 1000 miles more, I am getting inconsistent electronic behavior ...inconsistent screen messages to usb not charging...ugh.
Rusty Teeth
York,PA 17408
Did u see my pix on battery distribution fusebox loose. One terminal was touching another.
Also charged both batteries overnight.
Rusty Teeth
York,PA 17408
s
JeepEagle1
Greg
Wilmington, DE
2019 JLU Rubicon Punk'n Metallic
On the second day, I received the following message: "Stop safely vehicle will shut off soon." This happened right after I adjusted the temperature settings. I pulled over and shut the vehicle off and restarted. The message did not reappear and everything seems normal. Any suggestions?
Jeep Wrangler JL Battery Level Charging Low cel3dNBETyyhP0pMaYRvc
JeepEagle1
Greg
Wilmington, DE
I checked the distribution fusebox terminal and fuses and everything looks good.
BoisetheCat
Idaho
CR-V
i haven't had any issues but where would i find these fuses and such that might be loose? is it next to the battery? how would one know if they were loose
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Just aft of the main battery, plastic cover with 2 simple clips on the sides. Just press them down and feel them click into place. Most of mine were loose as well, just checked.
OFFREDDY
Akhil
San Jose, California
2018 JL Rubicon
Had the same message as above and the dealer called me and told me today that my power steering had been shorted? and a new gearbox has been ordered... Im going in today to pick it up. Any insight as to what questions I should ask the dealer to ensure this does not happen again would be great.
