Axle nut
Bobert7649
Robert
WV
2020 jlu black and tan
Is it bad to drive without an axle nut on the front? Dealer didn't seem to think it was a big deal.
Gorilla57
Chandler AZ
2019 JLUR Mojito
Are you talking about the axle nut or lug nut? You absolutely can not drive without the axle nut, but you can drive without a lug nut (for a short distance anyway).
rustyshakelford
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
how long are we talking about? The unit bearing is sealed. I wouldn’t wheel It but for a couple days I think it would be ok. Obviously not ideal but end of the world
brett
Bobert7649
Bobert7649
Robert
WV
brett
So far 4500 miles
Sprint7
Louisiana
2004 LJ 2018 JL
Would i drive off the trail and limp home with out an axle nut......Yes.
If a dealer told me that was ok for 4500 miles i would look at them like they had a horn growing out of the center of their forhead. Why will they not just put a nut on or simply replace the axle?
Bobert7649
Bobert7649
Robert
WV
Takes two weeks to get a nut they said, I feel like I shouldve got a loaner, since it was a factory foul up
Monkeynono
Southern New Jersey
2020 JLUR
That many miles is surprising without any issues. Maybe they changed there design. I know GM's do not need the axle to keep the bearing together. But as far as I knew Dodge and Jeep needed the axle
rustyshakelford
Brett
Navasota, TX
The axle shaft isn’t really going anywhere. It’s not ideal but certainly not the end of the world. You’ve driven it for 4500 miles and they are assuming all the risk should any damage happen between now and then. I might have some around the shop but we’re gone till early August
brett
The "wheel bearing" is a unitized hub, these days. Has been for many years.
The "nut" holds the axle in its lateral position so the axis of the stub axle U-joint is in line with the knuckle balljoints. If the nut isn't present, the axle can migrate inboard a small amount and some bind the U-joint. The axles cannot come outboard.
