Broken captive nut
Saejin
Gene
Colorado Springs
JLUR - Firecracker Red
Did they even offer to fix it for a price? To me the dealer would at least try to say we’ll fix it for xxx amount of money and then maybe you could negotiate a deal given that the body bolt should not break like that. Also, with that body bolt loose I wouldn’t go off roading until it’s fixed.
Do a search for the other user who had the same problem and maybe they can let you know how it was fixed.
TheCappy
TheCappy
Pittsburgh
JLUR
No, the service tech said we can't fix it and to take it to a body shop. They didn't even want to discuss it. They installed my mopar lift for under $300 though. I'm going back tomorrow because the steering wheel isn't straight after the lift install. Maybe I can get the service manager.
TheCappy
TheCappy
Pittsburgh
JLUR
Nobody seems to have my issue. I used the prybar/screw driver trick for the first two on the drivers side. This thing is just fucked.
JeepCares
Auburn Hills, MI
JL
MooseMob
Lynn
Las Vegas, NV
JLU Mojito!
I have developed the same issue with one of the bolts. The only solution I have seen is cutting a hole in the floor to access the nut/bolt inside. Are there other possible solutions?
TheCappy
TheCappy
Pittsburgh
JLUR
That's how I fixed mine.
dejohnson8034
Dennis Johnson
DFW
2018 Sahara JL Unlimited
I had the same issue happen to me yesterday, it was the last bolt, middle on the passenger side. Brought it to a 4x4 shop, they advised they would need to cut a hole in the floor and reinstall a new nut/mount. The torque on the bolt was ridiculous, only broke it free before the interior nut broke. I am reaching out to Jeep Cares as it should not break while removing it with a 18mm socket and ratchet.
Jeepsterfreak
Honda, Future JLU
Did you use heat to soften the loctite?
Maybe it was cross threaded from the factory.
