THAW
- Foster
- Oct 28, 2022
- PNW - prefer Middle of Nowhere
- 23 JL4DrRubicon
That behavior is expected. The PCR is normally closed, so the battery wiring would've been connected (i.e. not switched open) while you were tinkering.So, prior to pulling the aux batt, if I pulled the battery cables off the main battery, everything still had power as if the two batts were in true parallel wiring, as opposed to relay based A/B switching. So that power had to be coming from the aux batt.
In your case, pulling fuse F42 shouldn't make a difference. That fuse allows the PCR to open, and your PCR apparently isn't opening. Removing the fuse would turn off a dash warning light - but you don't have one.I want to pull the F42 fuse and see if it behaves differently. Just as a test.
Have you checked fuse F42 to see if it's blown?
