Automatic Tire Deflators - recommendations?
JEEPCINEMA
Cinema
2024 2-Door Sport
Hello Everyone,
Anyone have experience with Automatic Tire Deflators? I’m sure you all do 😅
Any suggestions on which ones are the best? Or at least most used around the Jeep community.
Thank you.
yokramer
Snark Incarnate
Just get hte cheap ones on amazon and double check them the first few times.
yokramer
Snark Incarnate
Usually the biggest issue with the cheap ones is they drift over time and you have to reset them.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
There are some where they're pre-calibrated. Calibrating deflaters like Stauns can be a bit painful, so consider that option. Don't do that with your first set, however, since you won't know what "normal" PSI you're comfortable with.
jadmt
jeff
montana
been using Stauns for many years and once you get them set and make sure the lock ring is tight they are pretty bullet proof...it takes a bit of work to get them set tho but for me they were worth it.
F4Flyer
Littleton
2024 Rubicon X
Stauns and Coyote both work well but now I just use the MORRFLATE system...so much easier.I air down to 12- all 4 tires when offroad. When done, I reverse the process (need the compressor for this step) and go to 28 PSI for all four. Done.
JEEPCINEMA
Cinema
2024 2-Door Sport
I’ve seen these. I’ll have to look into them more.
F4Flyer
Littleton
2024 Rubicon X
They are amazing. I don’t even know where my tire deflators are anymore. Kind of fun to use as well. The green Morrflate is the best one I like.
Grayhound
Michigan
Jlurd
I use the Amazon version of stauns I did not dial them in.
i use then wide open with the evic display and run around the jeep while they air down.
I’m normally able to set up my flag during this time as well.
