Antenna reception.
kayakman
lewis
cary nc
2021 wrangler Sahara unlimited, 2019 compass limited
The radio could be losing signal due to trees on the side of the highway blocking line of sight to the satellites. I've experienced this with both my truck and my jeep. Does it lose signal for more than a minute or two? Come in and out until you break out into the open?
The outage is under 30 seconds. But it occurs on the same road a few 100 feet apart
Wbino
NJ
XM will also drop out with a big dip in the road.
yokramer
Snark Incarnate
Wbino
NJ
but what about if he changes his antenna on the fender?
Not sure I don't stress, I come from a life of records that skip, 8 track that could change in the middle of a song or cassettes thhaaaatt pllayyed liike thhiisss.
The original XM receivers before they were installed in cars let you move the antenna wherever you wanted.
yokramer
Snark Incarnate
Same I just plug in my phone and listen to what I have downloaded
Odyssey USA
Daniel
www.youtube.com
2021 JLU Rubicon
I’m cheap…and I’ve done this on a few vehicles. I cut my factory antenna down to 16”?… and put a skinny vacuum cap on the end with silicone. I like it.
It did cut reception some. I still pick up decent FM signal about 25-40 miles away depending on terrain.
Heimkehr
Pennsylvania
2021 JLU 2.0T
I recently changed my stubby antenna because the reception was cutting out in certain areas. I bought the 13” rydonair. But the reception still cuts out in the same areas.
I wonder if there’s another brand that may be better. Any ideas.
thanx
There are a few owners here who've reported favorably on cutting X inches off of their stock antenna (the one on the fender, as you've mentioned), and reinstalling the small ball at the cut point. See post #21, above. They reduced the length just enough to avoid the whipping effect, while preserving the desired terrestrial radio reception.
Nokones
Kenny
Sun City West, AZ
In regards to XM Satellite coverage, there are extremely small areas/pockets of dead spots even in areas out in the open where there are no visual Line of Sight Obstructions. I have seven vehicle subscriptions, and all seven vehicles experience the same interruption/signal loss in the same spots for a brief second or two.
Mguy
Far Away
2020 JLUR 6spd MT
Until u mentioned a second antenna I didn’t know it existed. I had installed the roof insulation panels but since the interference occurs in the same areas it doesn’t seem like the panels are causing the issue
Roof insulation should have a cutout for roll bar Sirius XM antenna. Interference from physical obstruction(s) is cumulative.
Opus
Midwest US
www.jlwranglerforums.com
Note that Sirius XM requires line of sight to the various satellites. Is the area where it loses reception blocked by buildings / trees / a tunnel / etc?
I discovered that the SXM channels I listen to have satellites in the southern sky. If I catch a stop light at an underpass running east-west on my commute I lose signal until I have line-of-sight again.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
We're fairly confident (but not completely sure since he refuses to acknowledge it) that OP is having issues with SiriusXM and not FM.
21JLURDG
Olympia, WA
2021 Wrangler Unlimited Rubicon 3.0 Gecko
Yeah, I kept reading this thread to the end to see if he'd clear up the mystery. I thought he might be talking about GMRS. ;)
Ratbert
PNW
Software Engineer
If you want help that’s relevant you’re going to need to actually say whether you’re talking about Sirius XM or AM/FM radio.
It's like fucking pulling teeth.
I'm guessing it's XM.
He said he installed roof insulation panels, so that implies either a hard top or a SOT.
It's like fucking pulling teeth, but we tend to like challenges around here.
Terrymo
Terry
2023 JLURXR 3.6 ET
GMRS? CB? HAM?
