WranglerMan
- Will
- May 8, 2018
- Greenfield Indiana
- 2018 Wrangler JLU Sahara
- Occupation
- Retired
- Vehicle Showcase
- 1
I have used the Tazer two piece, Tazer Mini and currently use JSCAN, the Tazer I have to say is the easiest to use and handles all operations pretty painlessly and has excellent customer support, the JSCAN as @jludave has pointed out takes a bit more user interaction and does not handle some things as smoothly as a Tazer like ESS disabling as one has to disable a hood switch plus a few extra steps.
Now the down side, the Tazer has to be married to make changes and after that you can unplug and put away BUTā¦it has to be unmarried for service work because if you forget to unmarry it which puts it back to stock and then you take it in and they flash the PCM with software updates the next time you unmarry it the updates will be erased and require a visit back to the dealer so keep that in mind
JSCAN there is no process of marrying it to the Jeep you just make changes and unplug and if the dealer writes updates then all your changes are overwritten and you just need to go back in and change them.
I currently use JSCAN with a few different OVDII BT modules with a ECRI bypass module and never have to take it out as itās a bypass module.
There are pluses and minuses to both but if you are only doing some simple changes like tire size, tpms limits, gear ratio etc⦠then JSCAN would be the ticket but if say you want ESS disabled as well then Tazer
