Adjustable control arms
21JLURDG
Olympia, WA
2021 Wrangler Unlimited Rubicon 3.0 Gecko
Addressing several points in this thread without bothering to quote (because I'm lazy).
1. Your lift might be different for your model, but on mine TF doesn't sell a complete 4.5" short arm lift--but it's what I have. I started with the 3.5" (actual 2.25" incl. 0.75' spacers) with short adjustable CA but determined after several trails that I needed at least another inch because I kept hitting my skids and bumpers on ledges. When I swapped to the new diesel 4.5" coils, I actually ended up with a 5+" lift.
2. TF said I really should use the front CA drop-brackets to minimize the CA angle when using 4.5" coils. The problem was that the TF adjustable CAs are a little too long (I believe they're longer at shortest setting than OEM CAs) but I managed to make it work.
3. TF is not the best rock crawling suspension nor does it have the most flex. But I went with it because its reputation for well-built components, a better ride on rough roads, and good on-road and rock crawling performance.
4. You don't need a 4.5" lift to fit big tires, and a lower lift gives a lower CG for off-camber obstacles. A flexy suspension with good down travel can give good performance on rocks. But a taller lift with good up-travel can (i.e. right shocks and other components) give excellent performance at higher speeds on very rough roads. Most people I wheel with have a hard time keeping up with me on the flat portions, but it's definitely not a Raptor.
5. I couldn't be happier with the performance of my Falcon 3.3 shocks with my TF suspension. I did read beforehand that some people complained about overly stiff shocks. So on initial install, I set mine up in the cold weather/softer setting. After two years, they feel like they have softened a bit and I'll be switching them to the normal/stiffer setting in the spring. I'll emphasize that the Falcon shocks were designed to perfectly match TF suspension rates. For non-TF lifts, it's a maybe on the good match. A safer but more expensive option would be custom tuned Fox shocks.
If I were to do it all over again and I knew I wanted a 4+" suspension lift, I would have started with a mid-arm or long-arm kit.
I agree with others that said 2-2.5" lift with 35s look great for mall crawlers and easy trails up to 4-rated. It's hard to distinguish on these if they have 35s or 37s. For trails rated 5-7, I'd recommend 3.5" short arm lift with 35 or 37s. For 8-9, a 4-6" long arm lift with 37-40s. This is just my opinion and it doesn't address your experience and risk tolerance of damage, nor the type of trails in your corner of the world.
Zandcwhite
Zach
Patterson, ca
2019 jlur
Mid arm kiss for JLs are nothing more than marketing. The stock arms are a mid arm. The factory lowers are 24" vs a TJ/XJ at ~16". This kits are just stock length adjustable arms. Obviously they start at stock length and get a little longer, but that's not a mid arm on pretty much any other vehicle ever. It's marketing which is why you won't find a JL "short arm" kit. The stock arms are fine for 4.5" of lift, once you address caster. At minimum you need adjustable arms and track bars, but it's not some crazy height that needs long arms and custom axles to run well.
JEEP4U
Richard
2021 Jeep Wrangler
Did you do a custom axle? I'm all for the voice of reason, but I disagree that it's necessary for 4.5" of lift. With 3.5" I can run 6.5⁰ of caster and still have 0 driveline vibes even at highway speeds in 4HI. I seriously doubt 1" is going to be the breaking point. There are guys on here running 5.5" springs with stock axles. At 4.5⁰ I agree you'll need to address control arm geometry, but drop brackets and adjustable lowers will do the job. Of course custom axles and long arms would be better, but it's overkill for most.
I run TF long arm with custom front and rear axles. Custom 1350 driveshafts. My caster is over 10 degrees. No drivetrain vibrations and tracks much better than stock - on 40's. We drive I90 at 80mph often.
I have been told numerous times - This is the smoothest new Jeep I ever rode in. ......... "better than my daughters' new Jeep Sahara".
CowboysFan
Reese
TN
Jeep Wrangler 2024 Sahara
… OP?!!! Are you there?
Come on Guys be nicer next time!!!!
Nokones
Kenny
Sun City West, AZ
Don't forget about the Track Bars and your custom driveshafts and shocks. And, if you're going to run tires larger than 35s don't forget about chromoly 4340 axles and your diff gear sets by going to gears like 4.88 or shorter if you're going to be on 40s or larger.
bcupton
Bob
St Louis Mo
25 Wrangler Rubicon X
Retired Navy
Installing a 4.5” Terra flex lift in my 2024 rubicon 4xe. Trying to decide if the adjustable control arms are worth the investment not or if I can install later if needed. Any experience?
IMO you don’t have a choice if you do that type of lift. I did a 2.5” Mopar Fox 🦊 lift and after 2 years installed MC adjustable control arms set and my JLUS drives and rides 110% better!!!
