392 engine dies
Samsingh
Sam
Arizona
2022 JLU 392
hopefully its an isolated incident, its going to jeep next week so they can look into it further. In the mean time I have ramps at home, will try to replicate the issue with seatbelts on/off etc.
In the meantime maybe try to locate the fuel pump diagram? Any ideas where they may be
Samsingh
Sam
Arizona
2022 JLU 392
When you fill up at a station, when you're at 1/2 tank on the Jeep gauge, what does the gas pump register? Just wondering if the sensor in the gas tank is correct...
The tank has been registering fine as I fill up. I keep track of miles per tank and it seems to be measuring the fuel just fine. Apart from a bit of range anxiety on long trips its been working as it shoul
Antonio
Antonio
NJ
2022 JLU Rubicon diesel
can you replicates the problem?
you should video it and put it on YouTube/Facebook/instagram/onlyfans/pornhubs/tiktok with a title like "wrangler 392 engine problem" and get it public, or nobody will help you. Jeep dealer sucks.
my friend's 3.6 auto will just die in 4 low for no reason and no fix either, way passed warranty and dealer just say cannot confirm customer's concern.
Similar situation to this have already been posted on pornhub & onlyfans… its usually more then just sliding down… there is some rear ending too ???
ozon8r
Denver
2021 392 Hydro Blue
While I have not had the engine die, coming down about a two mile stretch above Breckenridge, CO, I started the hill at 50% fuel level, dropped to 1/4 within a few minutes and then zero before reaching the bottom. Scared the hell out of me and thought I may have punctured the tank somewhere on the trail. Once back on level ground and about 15 minutes later, the tank returned to 50%. And although I usually run with 2 3.5g fuel tanks, I knew the trail well, travelled a number of times and decided to leave the tanks knowing the trail would not require more than a 1/2 tank.
Here is a thread on my experience and contact with Jeep 392 Product Manager...
https://www.jlwranglerforums.com/fo...cal-scare-during-1st-year-of-ownership.97624/
Fortunately, the engine did not die like OP experienced. Sounds like the OP was going uphill though while in my tale, I was coming down a steep grade.
Lesson is that us 392 owners may want to keep more than 1/2 tank full on grades and may necessitate carrying aux fuel.
Spencer
Spencer
Idaho
2021 JLUR
Seat belt not hooked up. So when I wore the seat belt it wouldn't shut off. Some kind of safety issue.
Been wheeling all week in Sand Hollow. Last time I was here I had the engine stall on me back in 2022 doing steep climbs and it’s still doing it this time as well.
Read how you solved the issue by wearing your seatbelt. We tried that yesterday and it still stalled out.
Seems to happen when I’m using the Offroad Plus feature more than normal 4 low.
Did you also turn the seat belt chime back on? Mine is disabled through the Tazer.
TRMFAM
Rob
OK
What if you unmarry tazer, reinstall and only update gears and tire size and see if that makes a difference. There are so many electronics it could be some other unintended feature. Also, be sure to clear any codes you may have.
azjl#3
North AZ
Oil? Might the oil pump lose prime, lose pressure, kill the motor to save itself? Not sure if 392 has that feature, anyone?
But even if no feature, might the loss of oil cause 4 cylinders to stop working?
Just spittballing.
Spencer
Spencer
Idaho
2021 JLUR
Been doing some research. Speaking with others that have had this issue. Specifically the people at Rock Krawler. They have experienced this “safety issue” as well. There’s no solution. It’s to prevent the transmission from being damaged if the Jeep is rolling backwards. This issue even caused them to roll over. Their “solution” is to start the obstacle with more speed. lol
Once the tires start slipping and the Jeep loses its forward momentum the Jeep stops and requires you to put it in park. Sometimes the engine shuts off as well. Good times! Thanks @JeepCares!
Jeep Wrangler JL 392 engine dies 2636326139188825697
JeepCares
Auburn Hills, MI
JL
Hi @Spencer,
We regret to learn about your concerns. If you have an appointment scheduled with the dealership and would like extra support, please send our team a private message.
Blair
Jeep Cares
