1996cc
Oregon
22 JLUR 392
Advance Adapters FINALLY has the correct parts to make this work (even if they do scab 3 adapters together ?). I’ll save all the drama for another day, but the main case and some of the parts have been sitting on my shop floor since mid-December. Today the rest of the pieces showed up, so I left work early and dove right in. Here we go… (This won’t be a full step by step detail, but I will try to cover the points they don’t and any key details I think are important.
Original shipment-
Jeep Wrangler JL 392 Atlas transfer case install CADF563C-A9D8-4EDD-944A-AD8739B66FC8
The 392 specific parts that came today- (the instructions have you installing the bearing and spud shaft. My guess is this was their test fit one and they threw it in the box to get it to me ASAP since I’ve been religiously reminding them of my urgency- my current case is acting up)
Jeep Wrangler JL 392 Atlas transfer case install 84B2E2B0-A5BF-4930-B9EE-114D0682C213
Jeep Wrangler JL 392 Atlas transfer case install 5883D71C-FF66-4A98-B28F-65FBC1A44104
What instructions they do have tell you to cut the stock transfer case cable to remove it ??‍♂. I found it much simpler to just pop off this ball end joint and remove it intact.
Jeep Wrangler JL 392 Atlas transfer case install DC666FC6-A685-4112-AD29-12EB8188E1C0
Before removal-
Jeep Wrangler JL 392 Atlas transfer case install 1109D9AF-EB59-45BF-BED3-824A51E93916
Comparison pics-
Jeep Wrangler JL 392 Atlas transfer case install 5C8D7867-F0BF-4186-98ED-A8A098F90FF0
Jeep Wrangler JL 392 Atlas transfer case install 1CE249A9-D398-41A9-AEAE-EBB7496C80DC
Jeep Wrangler JL 392 Atlas transfer case install 16B28DDE-8953-4806-A37D-3A389BF9C2ED
Jeep Wrangler JL 392 Atlas transfer case install 00B9A8B1-88D5-4ACA-BD2B-A65F57616C87
Jeep Wrangler JL 392 Atlas transfer case install 0DC9FA09-F3C2-4210-8B0A-022883698FB3
Jeep Wrangler JL 392 Atlas transfer case install 15B9D0E1-83B0-47B1-8CEC-E88420CDA72B
1996cc
1996cc
Oregon
22 JLUR 392
Here are some measurements of differences. Overall length is 4.25” longer, so rear driveline needs shortened. Front output is 5/8” further back, so that will need lengthened. If they wouldn’t have added the 3/4” adapter thickness, the front driveshaft could have stayed the same. (This first pic isn’t showing the extra 3/4” for the front adapter)
Jeep Wrangler JL 392 Atlas transfer case install 2443DC42-DC2F-4B39-ACEF-16A9B6D5B7FD
Jeep Wrangler JL 392 Atlas transfer case install 5A75FBB5-553F-4997-ACFE-E6649771AD3E
Jeep Wrangler JL 392 Atlas transfer case install B6647EBE-DFF6-486B-BAAB-FD7996ECA54D
Jeep Wrangler JL 392 Atlas transfer case install C2408218-C0BF-41D0-824F-A6964C4091E0
1996cc
1996cc
Oregon
22 JLUR 392
Based on my measurements, I’ll be losing 1/8” to 1/4” of spline engagement on the transmission output shaft ? (not all photos shown, let me know if you really want to see them)
Jeep Wrangler JL 392 Atlas transfer case install E5459D29-1C7F-41F7-86AF-82674221E8F4
With the first adapter plate on-
Jeep Wrangler JL 392 Atlas transfer case install F71992EE-94D7-498E-8C93-BAF73A44A018
Just test fitting the main adapter-
Jeep Wrangler JL 392 Atlas transfer case install FF3C5DD2-3ED1-45F2-B81E-29C57060F4BD
Jeep Wrangler JL 392 Atlas transfer case install 3B2307B8-70BA-49BD-90BC-9A33F12A01F8
The stud position I used. It’s roughly 14 degrees of drop, stock was about 13 degrees. Each hole moves it 7 degrees-
Jeep Wrangler JL 392 Atlas transfer case install 45DD9025-36E6-4E11-90D0-EB9961F80B9A
Test fit with the case. It clears everything fine, much better than the diesel install we did in my buddies-
Jeep Wrangler JL 392 Atlas transfer case install 4423CAA8-98DE-4DFC-BA76-5E11D80069DC
Jeep Wrangler JL 392 Atlas transfer case install 01DA61CA-0757-435A-A104-4938B68F7030
Jeep Wrangler JL 392 Atlas transfer case install ECB8D5E3-F0BE-4643-AA99-2039CAC22AB1
DOOKEY
Andy
Thornton, CO
www.tractionoffroad.com
2021 GCM 392 - 2019 SG JLUR
Wheel Pimp.
Nissan
Nissan
israel
JL
It looks interesting, what gear ratio?
Do you have the possibility to take pictures inside the vehicle of the gearbox?
DOOKEY
Andy
Thornton, CO
Wheel Pimp.
1996cc
1996cc
Oregon
22 JLUR 392
I will, not that far into the install.
1996cc
1996cc
Oregon
22 JLUR 392
Measuring from the front mounting surface to the splines in the factory case-
Jeep Wrangler JL 392 Atlas transfer case install 4F70E2AB-B5AF-4162-886A-067E9288E9D3
Mounting surface of Atlas adapter to full spline height-
Jeep Wrangler JL 392 Atlas transfer case install 9450D018-8956-438F-A0E0-9A4DE87AADB4
Mounting surface of Atlas adapter to the base of the splines-
Jeep Wrangler JL 392 Atlas transfer case install 6511C984-D89B-4870-8968-DFE0DB91EFC6
1996cc
1996cc
Oregon
22 JLUR 392
I knew things were going too smoothly. Case is in the vehicle. Went to bolt up the crossmember and the rubber isolator mount interferes in a few places with the Atlas adapter plate. One of many examples of the fact Advance has never put one of these in each respective vehicle, allowing their customers to be part of their R&D department. It would be relatively easy to modify things to make it fit, but I’ll wait to see what Advance says tomorrow. I was at least able to take measurements for driveline modifications, to get that process started.
Jeep Wrangler JL 392 Atlas transfer case install 818A6241-635F-47ED-949C-AE272E6DBF9E
Jeep Wrangler JL 392 Atlas transfer case install FD1A0051-724B-4AAB-8AC5-40628DA65CD9
Jeep Wrangler JL 392 Atlas transfer case install AFA2773E-6C46-40A2-81F3-13457EEE0D55
Jeep Wrangler JL 392 Atlas transfer case install 281AC8F6-3DF8-4484-A6A9-8293F0CE10F5
Jeep Wrangler JL 392 Atlas transfer case install 13DB1EFE-847B-4601-A508-082A4E2F8A86
Jeep Wrangler JL 392 Atlas transfer case install AB3D4CDB-FCD5-43DA-BBCD-DC692FF9023C
Jeep Wrangler JL 392 Atlas transfer case install 8330AED0-A259-4A0E-AEDB-D7D2EC9CCA20
jbcrane
40.5853° N, 105.0844° W
Just a Jeep, M'am.
3D Animation
Man, that's really impressive. I would have absolutely no clue where to begin something like this - and envy your ability to tackle it. I'm not in the market for a new transfer case, I just find it interesting. Good luck.
Some Random Guy
Washington
Comptroller
Dumb question. Does this mean you can rotate the transfer case on the transmission to relieve driveshaft angles?
I have a 2-door 3.6 M/T Sport and the rear driveshaft angle is rough already. A longer T-case will make it worse. I have a concept to swap to an Atlas, but didn’t consider it would potentially make my driveshaft angles worse or be able to rotate to make them better at the cost of clearance.
1996cc
1996cc
Oregon
22 JLUR 392
The rotation of the case can help the front driveline angle, but it doesn‘t change the rear at all. It pivots on the axis of the rear shaft output. In my application, my rear driveline will have to be shortened over 4”. On the 3.6’s, I think it stays close to the same, based on Advance’s statements (but I‘be found them to be wrong many times now).
