Philly_
- Nov 20, 2021
- Dallas / Detroit / NYC
- 2022 JL Rubicon
- Build Thread
- Link
KC Cyclone V2 Amber Rock Light Kit
So I have fallen pretty behind on adding to the thread, but that's just because I have been out using the Jeep!
Haven't had the chance to test these out on the rocks yet, but I have used them on more than one occasion to light up the underbody when checking for damage or finishing up projects that require me to be under the Jeep. They are bright as heck! I believe they are the brightest rock lights with the best spread you can buy at the moment.
Hardest part of the install is figuring out where you want to run the wires, but after that it's pretty straight forward. I ended up using 4 of the factory brackets, and then magnets on the rest. To make sure I had all 4 corners covered, I also purchased an additional two light kit with the wiring from KC to make it easy on myself.
The front lights are mounted on Z brackets from KC and required minor fender trimming. The next pair are mounted to a rock rail bolt and another factory bracket just behind the front tires, then another pair just in front of the rears using magnets (not shown), and then I placed the last pair with magnets on the body mount bolts in the rear. They haven't moved at all in ~4k miles of on and off-road driving.
I have KC's bus bar wired into AUX 3 of the factory switches and zip tied down to an existing wiring harness to be easily accessible. All the excess wire is folded neatly, zip tied, and then tucked under the bus bar. I only have six attached in the picture, but KC's bus bar supports up to 12.
Safe to say, I am a big fan and am looking to add some clear ones for additional interior and under hood lighting!
Purchase Link
Back to Index
Purchase Link
Back to Index
