2.0 Oil Consumption
Wild_Willy
Will
Ohio
2020 Willys JL 2.0
Greetings. Long time lurker, but finally have a question that I can't find any information on. I have a 2020 JL w/ the 2.0 Turbo. Just turned 80k miles. It's been fine, a good running powerplant, until the last couple of weeks. It still runs fine, but suddenly it's developed quite an appetite for oil.
I check the oil regularly on all of our vehicles, but about 3 weeks ago I noticed the 2.0 was a quart low. Hmm. Unusual, but ok. Filled it up and checked it a couple of days later. It seemed a bit lower than when I filled it up last, but with the terrible dipstick on this engine it was hard to be sure. So, I let it go a couple of more days and it was low - another quart. So, I topped it back up again.
Long story short-ish, over the last 3 weeks, I've added almost 4 quarts of oil over the course of maybe 2k miles. Never had an issue before like this. Nothing leaking, not burning oil as best as I can tell. All the plugs look good. I do all my own maintenance and it gets full synthetic and a new filter every 5k. I'm stumped. Anybody have this type of issue before?
NWJeepr
Twin Peaks
2025 Wrangler 2-door
On a turbo engine, I'd also consider the turbo suspect. The seals can start to fail and oil can get past them and oil gets thrown into the exhaust. Not exactly sure how to check the seals, hopefully someone else will chime in.
Old Dogger
Bill
Cave Creek Arizona
Welcome back to the Forum!
If not leaking, then the engine is burning the Oil. Probably turbo caused. But if the engine has been ingesting silicon (dirt), then it could also be worn piston oil control rings.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
It’s burning it. Engines aren’t magic.
Either a bad turbo, pcv valve or piston rings. Valves seals wouldn’t get that high of consumption.
Does the 2.0 have the European style oil separator/pcv diaphragm?
Wild_Willy
Will
Ohio
2020 Willys JL 2.0
Thanks everyone for you input so far. I will look into replacing the PCV valve to start.
I don't know. How would I know the difference?
mwilk012
Oklahoma
Service
I checked, it does.
4893609AD, it’s listed as an “oil separator”, a large plastic housing that has baffles to encourage oil to drain from the PCV air flow path. The drains in them can get clogged and cause high oil consumption.
cripton805
Vic
Santa Maria, CA
2018 JLU Sport w/ 6sp
I don't think they're the piston rings or turbo for a few reasons. It seems like it happened more suddenly vs. gradually over time. When rings wear out, you will notice a slow increase over time. At your mileage, I don't think you would have worn the rings unless you ran it without any oil.
You could have a shop run a compression test if you're really worried about that. The diag and labor fee will cost you a lot more than the PCV Valve. So, I'm hoping it's just a stuck PCV. It's a fairly common failure in all cars. Some people even replace them as a normal maintenance routine.
mwilk012
Oklahoma
Service
The cheapest option by far is properly diagnosing the issue.
cripton805
Vic
Santa Maria, CA
It's a good educated guess. I'd be willing to risk $50 over a couple hundred dollars on a compression test & diag. Just to have to spend $50 on the PCV anyway. But that's just my opinion. 🤷
It's easy to replace a PCV.
mwilk012
Oklahoma
Service
Have you replaced an oil separator on a 2.0?
compression testing is a waste of time here.
Wild_Willy
Will
Ohio
2020 Willys JL 2.0
Thanks everyone for your input. I'll try changing out the PCV first and see how that goes first and then report back. And you're right @cripton805 , it has happened rather suddenly, which makes me think it's not rings or the turbo itself. Either of those would have happened slower, over time, versus how quickly this problem came on. And with 81k miles, I wouldn't expect there would be a major problem with the engine yet, but with FCA/Stellantis quality control anymore, who knows.
8ball
Tennessee
2024 Jeep Sahara 2.0L
Let us know what you find.
Shibadog
Bowling Green, Ky
2020 Wrangler Sport S hardtop
You did verify that the radiator isn’t showing oil. In the coolant? If the coolants good, I’d bet on the PCV
