2.0 Engine Skid Plates
Robnfl
Robert
East Tennessee
2021 JLUR 3.0 Diesel - Firecracker Red
Retired USN
I also have the aluminum asfir setup. I wanted aluminum to save weight and wasn’t ready to shell out $2000 for a full underbody system. I’m happy with it and don’t recall having to pay any special taxes on it. Easy to install.
I haven't installed my ASFIR engine skid yet. The install directions, if you can call them that, say to remove one of the cross members before installation. Is that cross member replaced at some point?
MILT
Milt
MN
2019 JLU Sahara
Honda technician
No that cross member is replaced by the skid
Odyssey USA
Daniel
www.youtube.com
2021 JLU Rubicon
Hmm. I wonder what the net weight gain after install is then. Was it the small one with the holes in it? Did you weigh the skid and hardware?
jason0341
jason0341
Jason
2020 2.0L Rubicon
It’s the one with the holes. It might weigh roughly 10lbs or so nothing major.
Odyssey USA
Daniel
www.youtube.com
2021 JLU Rubicon
What was the ship weight on the engine skid plate? I’m a car guy still so I can’t stop caring about weight.
jt48324
Joel
Michigan
2020 JLUR, Rock Hard Aluminum bumper, Warn 10k, ASFIR aluminum skids, Westin rock rails, 35" Wild Peak A/T
I should get mine this week. I wrote the company asking for the weight and they provided the following?
547459 – Engine skid plate – 12 kg (26.4 lbs)
547465 – Transfer skid plate – 2.4 kg (5.3 lbs)
I did not order the fuel tank skid since there is already a light weight one on my Rubicon. Thought I'd see how that one holds up before I replace it. 32 pounds less the weight of the crossmember I remove seems pretty light to me for the protection.
Joel
Instaurare
Arizona
2018 JL 2.0 turbo
I have a 2.0 JLR, are the same skids used for the 2.0 and the 3.6? And is there any interference with changing the oil filter on the 2.0? Thanks.
Odyssey USA
Daniel
www.youtube.com
2021 JLU Rubicon
If you go to the Asfir site, I believe there’s two different engine skid plates.
jason0341
jason0341
Jason
2020 2.0L Rubicon
I have the full Rusty's skid system.
The skids are thick, heavy, and appear to be high quality. It installs very easy, aside from the fuel tank skid. The tank has to be lowered.
Warnings:
If you are not lifted, you will not be able to install the oil pan skid. There is an arm that attaches the skid to the motor mount that contacts the axle under compression.
Be careful with the fuel tank, even disconnecting everything during the install a pin got pushed in tripping a CEL.
Is this on the driver or passenger side? I just installed the ASFIR skids, I’m not lifted yet (soon to be 2wks) I wonder if there is an issue there as well under compression. any way we can see a couple pictures of yours? Thanks
