I agree, but I think his method is fine for the same tread -- i.e. both Baja Boss tires. I think this is the reason why the KM3 gave the illusion of a larger contact patch area, however.I don't agree with how he is measuring contact patch area. In my opinion, it should just be the rubber contacting the ground, not including the air space between the tread.
5:00 in the video shows his method.
If you have any interest in IFS (or just geek out on suspension), his other videos are done with the same approach. I disagree with his JL comparison, but he's a Yota fanboy so you'll get some of that.Probably the best Jeep video I’ve ever seen, and it’s not really even about jeeps. Just love the scientific breakdown and the hard work that went in to the video. I’d love to see the difference between a Ridge Grappler and a BFG.
I’ll definitely check out the other stuff. I could tell he loves Toyota but that’s okay. I can ignore that and enjoy the scientific contentIf you have any interest in IFS (or just geek out on suspension), his other videos are done with the same approach. I disagree with his JL comparison, but he's a Yota fanboy so you'll get some of that.
Toyo now sells the A/T III in that size at a normal price.Years ago I had a set of 34X10.5R17 KO2s on my 2015 Sahara. It was the perfect size for a 4,400-lb Jeep IMO. The problem is that’s an odd size; those tires are freaking expensive.
Agree, his suspension stuff seems a lot more insightful in a controlled environment.This video demonstrates the obvious.
For example:
A) The LT255/85 R17 load range E tire has a maximum inflation of 80psi. At 80psi the load capacity of the LT255/85 R17 tire is 3195 pounds
B) The LT315/70 R17 load range E has a maximum inflation of 65psi. At 65psi the load capacity of the LT315/70R17 tire is 3195 pounds
Load Range is primarily intended to describe the maximum air pressure and the maximum load capacity a tire can provide.
Load capacity is a function of the mass of air that may be stored in the tire, so when the comparison is made at the same inflation PSI it should be blatantly obvious that the tire with a lower volume will have a greatly reduced load capacity, and therefore deform more dramatically than the tire with greater air volume.
It would be helpful for that video to point out that "load capacity" is a basic characteristic of a tire, and explain why we should expect the tire with lower volume to provide decreased load capacity.
It would seem pertinent to point out that the maximum load capacity of either of these tires exceeds the static load presented by the particular vehicle by over 100%.
When we use these LT pavement tires to crawl offroad at low pressure we are utilizing them in a manner contrary to what they are designed and manufactured to accomplish.
It would also seem helpful to observe that dynamic loading differs from static loading. In other words, a tire simply resting on top of a rock, is under different, and less stress than a tire that is climbing and or bouncing over a rock while it is being forced into the rock by the drivetrain.
I recently purchased a 4 Runner to use as a country drive station wagon, and have enjoyed some of the Tinkerer's videos, but when I watched this video a few days ago it struck me as a very complicated exercise in discovering the obvious and presenting it as entertainment.
Cool feedback. Most (like all three) 35/11.5/17 tires I’ve seen are load range C. Curious whether the 315s or 35s you mentioned were load range E or D? Just trying to evaluate whether that had any impact on your experiences.I have owned 315/70R17 and 35x12.5R17 four times: on my 2012 Rubicon 4-door, 2013 Rubicon 2-door, 2018 JKURR, and my current JL Sahara; all with a Mopar lift - I never liked how the Jeeps felt on-road on tires that size. I could feel the added heft and width in the corners and over bumps.
I recently switched my JL from 35X12.5R17 to narrower 285/75R18 (i.e., 35 x 11.2 inches) tires. The skinnier tires weigh 10 lbs less each. I immediately felt the improvement in the cornering and the ride. There’s much less tire bounce coming in through the steering wheel and the suspension.
