Larger tires vs odometer comparison chart?
Lustmord
B
Los Angeles
www.lustmord.com
Rubicon JLU. It's a Jeep.
I had a chart bookmarked that showed the odometer vs actual speed with larger tires but can't for the life of me find it, does anybody have anything like that on hand?
- putting 35" on my Rubicon and while I wait for my Tazer I'd like t have an idea of my actual speed in the meantime.
Yellow Cake Kid
Jeep
π2R
33" tires: 3.14 x 2 x 16.5in = 103.62in
35" tires: 3.14 x 2 x 17.5in = 109.90in
about a 6% difference
Which is to say that when the speedometer says 10mph you are actually traveling 10.6mph, or when you think you are going 100mph you are traveling at 106mph.
70mph will be approximately approximately 74.2mph.
In other words, not a lot of difference.
Jeepsmashin
Corona ca
Use a GPS app on your phone to give your accurate speed.
I believe my JLUR is showing 3 mph slower on the speedo than what I'm actually going. The faster I go the less accurate the speedo is.
This is with 315/70/17 MT
TheBirdie72
Rhode Island
2021 Jeep Wrangler Freedom Edition 2 Door
When your speedo says that you at traveling at full impulse, but in reality you are now moving at warp 1.5…
Jeep Wrangler JL Larger tires vs odometer comparison chart? 8E3810CA-ECE8-4F20-A6CB-1DEF22B2F8F3
:LOL:
OldBlue
Doug
Chatham Twp, OH
See my Signature
Aerospace Forgings Test Lab
HERE'S a speedometer calibration calculator. It might help.
BuyHold
Tim
Washington
'21 2-Dr Rubi, '23 JTM
Assuming no calibration has been performed, the easiest way to mentally adjust is to just take ratio of New Tire Diameter over your Factory Tire Diameter and multiply by dashboard speed.
For example, if you have a Rubicon and have installed 35 inch tires. If your Jeep dashboard says you are going 60mph then 60 x (35/33) is your true speed... So 63.6mph. (this works to same 6% difference @Yellow Cake Kid used in his example).
You don't need Pi or anything like that to do this since the equation reduces to what I described above... New Diameter over OEM Diameter.
Lustmord
Lustmord
B
Los Angeles
www.lustmord.com
Thanks guys, very helpful!
I'm usually doing 75+ when on the freeway and just don't wish to stand out to the highway patrol until I get the Tazer (smile)
BuyHold
Tim
Washington
If your Speedometer says 75 then you will actually be traveling at nearly 80mph with 35s and no recalibration. In LA you would still be slowing traffic behind you down at that speed, no?
J0E
J0e
Hawaii, MT, SLC, NYC
bt39.com
2021 JLR, 05 LJR on 43s
2nd 392
Ca
O
Or you will be crawling in stop and creep LA traffic. But either way-No Tickets.
