Wrangler 2029 Model Year
Twisted10
Brandon
Western NY
2023 Wrangler 392 XR/2022 Ram Cummins
I asked AI if it was a credible source for information on what the details of the 2029 Jeep Wrangler would be. Here’s your answer.
You don’t need to read very far. But if you’re curious AI is quick to admit its flaws. Why people on the forum use it as a source or in many casss to appear smart is baffling.
Same as people who watch the news and think its gospel.
Jeep Wrangler JL Wrangler 2029 Model Year {filename}
gato
New England
2021 JLUR
The product mess/limbo that Stellantis is in (and the start of corrosion on my hood) is the reason I decided to sell my 2021 and buy a 2026. I had an extended warranty through March 2028, but I didn't think the new platform would be ready AND debugged/supported by the aftermarket till 2030-2032. Had I not bough a 2026, I know I'd feel the itch and end up jumping on a first year platform and regret it.
Stellantis at this point is just as likely to extend the life of the JL generation indefinitely as they are to launch a new planform.
west tex
Skoro
2021 JL 2dr 80th Edition, 2017 Renegade Trailhawk
Retired, as in "Tired again"
I did a quick AI inquiry and this is the result.
The next-generation Jeep Wrangler (internally designated as the J70 generation) is scheduled to be fully redesigned for the 2029 model year, with production expected to begin in 2028. [1, 2, 3, 4]
The current JL generation—which originally launched for the 2018 model year—is wrapping up its production run. The upcoming 2027 and 2028 model years will serve as the final "carryover" years of the current platform, seeing only minor tech tweaks, package updates, and limited-edition colors. [1, 2, 3, 4, 5]
Will the Two-Door Rubicon Survive the Redesign?
Yes, but it faces major changes. While the roomier four-door models make up the vast majority of consumer sales, Jeep plans to retain the classic, short-wheelbase two-door platform for traditionalists who value its superior turning radius and heritage look on the trail. However, the mechanical blueprint of the J70 Rubicon will shift dramatically: [1, 2, 3]
  • Massive Electrification Shift: The biggest change for the 2029 redesign is the powertrain. Jeep's parent company, Stellantis, is phasing out pure internal-combustion engines for the Wrangler line. The next-gen Rubicon will primarily rely on a range-extended electric vehicle (EREV) setup. This utilizes electric motors to drive the wheels, paired with a small gas engine acting purely as an on-board generator to eliminate trail-range anxiety. [1, 2, 3, 4, 5]
  • Instant Trail Torque: For off-road enthusiasts, the electric transition brings massive advantages. The next-gen Rubicon will benefit from instant, maximum torque at zero RPM, allowing for incredibly precise crawling over boulders without needing a traditional multi-speed transfer case or low-range gear hunting. [1, 2, 3]
  • Modernized Infotainment & Telemetry: The rugged, hose-out dashboard layout will be completely overhauled with larger screens and integrated, real-time satellite trail mapping systems. [1]
  • Upgraded "Trail Rated" Benchmarks: Jeep plans to push its rugged hardware even further, targeting a new "Trail Rated 12" certification for the next-gen Rubicon by engineering advanced electronic sway-bar disconnects and independent wheel articulation. [1, 2]
The Current Two-Door Status
If you prefer a traditional internal combustion engine (like the 3.6L Pentastar V6 or 2.0L Turbo) mated to a mechanical 6-speed manual transmission, you should look closely at the current model years. The 2026 and upcoming 2027 two-door Rubicons represent the peak mechanical refinement of the traditional gas-powered Jeep era. [1, 2, 3, 4]
hmmm...
Jeep going to a totally electrified drive train with the ICE only there to run a generator. Excuse me if my skepticism has pegged the meter. The 4XE experiment didn't yield positive results. 🤔
Ramboy
2025 Wrangler Rubicon
Stellantis has already traveled the EV/motor route with the Rev; 3.6 engine as backup to full time electric.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
I'm not sure what you mean by "already traveled". The Ramcharger was supposed to be released in late 2024. None of that lineage has hit the streets yet. And definitely not in a Wrangler.
ASSFROW
Gary
Mt. Airy, MD
2024 Rubi X
"3.6 engine as backup to full time electric" Epitome of oxymoron.
ASSFROW
Gary
Mt. Airy, MD
2024 Rubi X
600+ horsepower / 600+ lb-ft of torque with 600+ miles of range isn't worth a look?
Depends and that wasn't the point of my reply. You're literally carrying around a 600 pound, 3.6l gas powered generator to power 400lb of electric motors and change the 1200 pound battery that you charged at home to start with. The damn thing weighs like 8000 pounds with twice the fire fuel and multiple ways of burning as Stellantis products are known to do. If I needed a work truck that never left the pavement maybe. My F150 had over a 600 mile range, but it only made 400hp and 400lb-ft of torque, but it didn't have all that crap including the damn near zero ground clearance from the electric motors.
