Micron Man
I did a quick AI inquiry and this is the result.
The next-generation Jeep Wrangler (internally designated as the J70 generation) is scheduled to be fully redesigned for the 2029 model year, with production expected to begin in 2028. [1, 2, 3, 4]
The current JL generation—which originally launched for the 2018 model year—is wrapping up its production run. The upcoming 2027 and 2028 model years will serve as the final "carryover" years of the current platform, seeing only minor tech tweaks, package updates, and limited-edition colors. [1, 2, 3, 4, 5]
Will the Two-Door Rubicon Survive the Redesign?
Yes, but it faces major changes. While the roomier four-door models make up the vast majority of consumer sales, Jeep plans to retain the classic, short-wheelbase two-door platform for traditionalists who value its superior turning radius and heritage look on the trail. However, the mechanical blueprint of the J70 Rubicon will shift dramatically: [1, 2, 3]
The Current Two-Door Status
If you prefer a traditional internal combustion engine (like the 3.6L Pentastar V6 or 2.0L Turbo) mated to a mechanical 6-speed manual transmission, you should look closely at the current model years. The 2026 and upcoming 2027 two-door Rubicons represent the peak mechanical refinement of the traditional gas-powered Jeep era. [1, 2, 3, 4]
- Massive Electrification Shift: The biggest change for the 2029 redesign is the powertrain. Jeep's parent company, Stellantis, is phasing out pure internal-combustion engines for the Wrangler line. The next-gen Rubicon will primarily rely on a range-extended electric vehicle (EREV) setup. This utilizes electric motors to drive the wheels, paired with a small gas engine acting purely as an on-board generator to eliminate trail-range anxiety. [1, 2, 3, 4, 5]
- Instant Trail Torque: For off-road enthusiasts, the electric transition brings massive advantages. The next-gen Rubicon will benefit from instant, maximum torque at zero RPM, allowing for incredibly precise crawling over boulders without needing a traditional multi-speed transfer case or low-range gear hunting. [1, 2, 3]
- Modernized Infotainment & Telemetry: The rugged, hose-out dashboard layout will be completely overhauled with larger screens and integrated, real-time satellite trail mapping systems. [1]
- Upgraded "Trail Rated" Benchmarks: Jeep plans to push its rugged hardware even further, targeting a new "Trail Rated 12" certification for the next-gen Rubicon by engineering advanced electronic sway-bar disconnects and independent wheel articulation. [1, 2]
