I got the CarLinkit 2.0 (usb-c version) today and it's done nothing but constantly reboot, flake out, and ultimately cause CarPlay to go completely insane on the uConnect even with a hardwire connection now. Hoping that at least clears up after Jeep sits overnight. It was cool when it worked, but it won't stay online for more than about 10 minutes before it reboots itself.I would go with one of the other brands that are more commonly used by those on this forum - CPlay2Air or CarLinkit.
I have one of the original design CarLinkit adapters and it works perfectly. All CarPlay functions work and the sound is no different than when plugging in or streaming normally via bluetooth.
I am trying to update the FW with no luck, but if it doesn't improve I'll be sending mine back.
I have this one and have zero issues and also have the latest iOS update https://www.amazon.com/dp/B08767RQDB/ref=cm_sw_em_r_mt_dp_A21Q1X8BAVZR9ZCBHD49?_encoding=UTF8&psc=1I had the same issue with that crappy device kept rebooting so I pulled the plug and through it away. I have no time for that S%$t! I now just plug it in Like I used to with the apple plug... Done!
That's what I have and mine, at least, is total garbage. Maybe I'll try a second one but this first one hasn't impressed me at all.I have this one and have zero issues and also have the latest iOS update https://www.amazon.com/dp/B08767RQDB/ref=cm_sw_em_r_mt_dp_A21Q1X8BAVZR9ZCBHD49?_encoding=UTF8&psc=1
The only thing I did per there suggestion was removed any possible BT conflict while in the vehicle so I had my phone originally paired with Uconnect but removed the paired connection and just paired it with the Carliknit 2.0 and so far after just a few months it’s been solid.
I thought it was confirmed the USB power cuts off after 1 hour?It also tends to drain the battery because it's always connected via the USB
It depends on who u ask. The manuel says it shuts off after an hour. However my battery died and was replaced by dealer. He said absolutely the USB does not turn off and i'm not going to gamble I returned it to Amazon. It's a painI thought it was confirmed the USB power cuts off after 1 hour?
Even an hour is bad, IMO.It depends on who u ask. The manuel says it shuts off after an hour. However my battery died and was replaced by dealer. He said absolutely the USB does not turn off and i'm not going to gamble I returned it to Amazon. It's a pain
It does not. The USB ports in the JL power down after 1 hour. It's been discussed here before and is in the owner manual.It also tends to drain the battery because it's always connected via the USB
Yes, it has been. I have a CarLinkit device and have no battery issues.I thought it was confirmed the USB power cuts off after 1 hour?
Did you do a FW update as soon as you got it ? If so they dont recommend doing that unless your having issues also try removing the pairing between your phone and Uconnect if it’s pairedThat's what I have and mine, at least, is total garbage. Maybe I'll try a second one but this first one hasn't impressed me at all.
