Albertaktm
- Randy
- Jan 29, 2020
- Alberta FootHills
- 2023 Willys 2 Door Manual.
- Occupation
- Chief Cook and Bottle Washer
I have actually never seen any fluid with an above freezing designation. In Canada its called Summer washer fluid. It has solvents in it to dissolve bug guts, tree sap and helps with streaking. Any washer fluid is methanol based and can be used below freezing. It isn't as effective when the temp really dips. ( not the stuff in Texas, Louisiana right now. Really cold! -30 cold) Then you will have problems when you drive. Like freezing on the window.You post is a tad hard to understand...
+32 windshield washer fluid will freeze if temps dip below 32 degrees for an extended time frame.
In colder climate areas +32 degree washer fluid will in fact freeze in the wiper hoses and in the windshield washer reservoir.
-20 and -40 windshield fluid is readily available and should be in the windshield washer system in the Wintertime if the vehicle will reside in / or visit locales where temps dip below freezing... below 32 degrees.
