Windshield washer spray
Crso8541
Alabama
JLUR
Heli Pilot
Washer fluid got low, added more washer fluid and now there’s barely any pressure coming out of the squirter’s on the hood? I’ve checked the hoses for kinks and did my best to look in the reservoir for any type of gunk buildup, Anyone got any ideas?
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
Probably stirred up some garbage when you added fluid and subsequently got pushed into the hose and clogged the squirters.
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
My first question is what windshield washer solution do you use?
Hint to all: Do routinely, use both your front and rear windshield washers.
Do this and you will be a tad less likely to have a plug develop. Also, watch what windshield washer fluids you use.. do not mix brands of fluids..
Here is a video that will give you an idea how to unplug the fluid lines and may also clear a plugged windshield washer reservoir filter.
JLRyder
2019 JLUS
This is a common problem. There is an inlet screen on the pump that gets clogged also. There is a rubber connection coming off the pump (bottom of the rez). Pull it and blow compressed air into the line and into the pump, this is what fixed mine.
RatZero
Canada
2024 Willys JLU
Manufacturing @ Stellantis
The washer hoses and spray nozzles aren't too hard to remove and reinstall. If you think there's a blockage, you could remove them and blow out the hoses and soak the nozzles in 50/50 water/vinegar or vinegar/baking soda.
Crso8541
Crso8541
Alabama
JLUR
Heli Pilot
Awesome, not sure why blowing air through them didn’t come to mind, lol
Rhinebeck01
Retired at 55 ..
Just for reference in case anyone reading this thread needs to replace a nozzle or a washer fluid level sensor.
Frt. Mopar Nozzle-Windshield Washer 68293025AA
Nozzle LiftGate Washer 68293253AA
Washer Fluid Level Sensor 05152029AB
