FreedomFur
- Elliot
- Oct 26, 2021
- Concord, NH
- 2021 JLU Willys
You basically hit on the points I was thinking about. Especially if I only plan to run 37 or maybe a 38 inch tire.The ProFloat really minimizes the issue had with both JK and JL/JT rear axles- bent wheel hubs. The JK/JL/JT all have a wheel bearing that is significantly further inboard than the previous TJ Jeeps. I can't really remember seeing a TJ with a bent axle flange. The deeper wheel bearing allows more leverage on the flange and is the reason (along with weight) so many JK/JL/JT failures are seen.
The Dynatrac ProFloat axle addresses these issues.
No question, a full float design is superior to a semi-float design, but, it's not always needed. A bloated JL/JT on 40's should have a full float but if you stay under 6K# this should be a great option.
