When Do You Know That Welds Are a Problem?
Seansun01
Massachusetts
2018 Wrangler Unlimited JL, build date 12/12/17; 2015 Harley-Davidson Heritage Classic Softail
I had to retrieve something from under my Jeep the other day and I noticed that there was a lot more corrosion than I would have expected for a vehicle with less than 12K miles. Further inspection led me to look more closely at the welds, almost all of which are corroding. I’m no welder but I can solder jewelry and these welds look pretty awful to me. Some are off-center, others very porous, some look like they’re cracking, and some are not even completed. How bad is too bad?
Jeep Wrangler JL When Do You Know That Welds Are a Problem? 72DB9AE4-504A-4B9A-81B8-F902AEF931C6
Jeep Wrangler JL When Do You Know That Welds Are a Problem? EA5ED276-6533-466B-A619-DAE93D7FBA44
Jeep Wrangler JL When Do You Know That Welds Are a Problem? E0F34DFE-9D00-44AB-ADFE-52B3788871BF
Jeep Wrangler JL When Do You Know That Welds Are a Problem? 08D199A1-D10A-4CEB-B475-1069936B1272
Jeep Wrangler JL When Do You Know That Welds Are a Problem? 7D3D7BA0-2112-40CB-A9BA-B3CFF7E5CD55
Jeep Wrangler JL When Do You Know That Welds Are a Problem? 031DA335-CFBB-4EC8-8BE5-8C53B3BD7B3B
MikeLewisMusic
Lexington, KY
2018 Jeep Wrangler JL Rubicon 2 Door, 2.0l Turbo/Automatic
Mechanical Engineer
Some of those didn't penetrate, the cracked welds are definitely a problem, and porosity in the one you show definitely impacts the strength of the weld. I think your eye is good and your instinct is right on, there are issues down there.
I've run structural weld businesses for over 30 years, I wouldn't let anything that looked like that out of my facility.
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
Yikes! Looks like I lucked out, the welds on mine look nothing like the pictures... (bot) welder having a field day on your frame...
lightsout
PNW
Mine goes in for welding on May 2nd, mine do not look as bad as yours.
Seansun01
Massachusetts
Nomars
Ramon
Los angeles
2018 JLUR, 2004 TJ
That rust is bad!!! My 15 year old TJ jeep does not have that much rust! Could be because ur up north east? Or are Jl chassis not as durable???
Time will tell, the gauge of steel on 4door Jl is def thinner, compared to a Tj chassis!!!!! Could be do to stronger steel being used? Or engineers reducing guage to save on weight goals? But is it more prone to Rust??
WXman
Central Kentucky
Pause the video at 5:14 and look at those horrendous welds on the rear control arm brackets. Apparently FCA still hasn't gotten this figured out even on the new Gladiator.
Turbo_punkn
Greg
Bath, pa
2018 JL
I’ve seen better welds on the Chinese bumpers you can buy on eBay and Amazon! I’d definitely take it back and bitch!!!
