What "U" Joints is everyone Using
Muskoka Minute
Bart
Muskoka Canada
2019 JL Rubicon
I have a 2019 Rubicon and she needs front shaft "U" joints.
I was looking at these.
Spicer 5-7166X 1350 Series U-Joint Kit
Are these the right ones?
Or what is everyone using or like better.
All recommendations please .
ParadigmDawg
Greg
Fort Worth TX
No idea what driveshafts you are running but if the are stock, they sure aren't 1350s. In all likelihood, the are 1310s.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
This is for the axle shafts.
I believe this is right. The Mopar P/N is 68476678AA and is the same as the JKs and JTs. F'in Mopar lists these at $166!
JEEP4U
Richard
2021 Jeep Wrangler
I utilize CTM Racing 1480's on my Jeep JLU.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
I ditched the u-joints in favor of RCVs.
But for the most part I go with spicer joints when I use u-joints
Muskoka Minute
Muskoka Minute
Bart
Muskoka Canada
2019 JL Rubicon
I do have a M210 & M220 set up.
I am looking for the the front axel "U" joint. 😀
Thanks for the mopar number.
Does anyone happen to know the Spicer number....
Thanks again for all the input.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Looks like 57166X is the Dana-Spicer number.
jellis4148
Missouri
2019 Jeep Wrangler JLU Rubicon
I did not know the axle shafts were 1350 u-joints. I assumed they were 1310. I have a spare axle shaft u-joint just in case and assumed it was the same size as all of them. So, to clarify my drive shaft is a 1310, and my axle shaft is a 1350?
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Factory driveshafts use Rzeppa joints for 3 out of the 4. Both outputs on the transfer case and at the rear axle. Front axle has a flange that accepts a 1310.
Pretty much every truck has stronger axle shaft joints since the differential multiplies torque and there is a lot more stress at the knuckle because of it. Apparently the factory has 1350s at the shaft.
I went aftermarket on my driveshafts and have 1350s. Double cardan joints at the transfer case and a similar flange on both axles that accept the bigger 1350 joint adapter.
Nokones
Kenny
Sun City West, AZ
23 Rubi, 21 Silverado, 13 Grand Sport, Cayman GTS,
Unemployed For The Rest Of My Life from a career of spreading love, cheer, and joy to lots of special individuals that were asking for attention..
1350s with Tom Woods driveshafts.
jellis4148
Missouri
My front drive shaft is a double cardan with 1310's.
