Welding (stick) on frame.
19 JLUR Bright Whit3
Baba Yaga
NJ
www.youtube.com
Retired LEO
I want to weld some tabs on my frame and slap a couple of spot welds on the exhaust. What precautions do I need to not fry the electronics? disconnect the battery? Where at? The "red" terminal? Thanks.
Electrified
2022 392XR
Not Jeep specific but when we did some stick welding on the frame of our 2019 RV, we completely disconnected the batteries (both house and cab) and did not suffer any electronic damage.
Roky
Roky
If you have the 2 battery setup, disconnect the negative cable and then take the auxiliary negative off the main neg cable. If you don’t take the cables apart the aux battery will still be hot.
Baba Yaga
NJ
www.youtube.com
Retired LEO
Thank you.
word302
Oregon
JLU
I'm not sure how long it takes to bleed off all the residual power from all the components, but I'd give it 10 minutes or so after disconnecting the batteries.
blnewt
New Mexico
Just ask @cosine he knows!
Also connect your welding ground as close as you safely can from where you will be welding.
To add to this, make sure the ground clamp is on bare metal. Paint is an insulator.
blnewt
New Mexico
Good point! I use a small wire wheel or that little sanding roll on my dremel, has worked well for that.
