Warn winch remote control?
tony58
tony
rome pa
2024 2 door rubicon,77 fj40,2010gt500,2021f250
I have a 2024 rubicon with the factory installed winch is there a wireless remote for that winch, thanks
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
donmontalvo
Don
Livingston, TX
donmontalvo.com
2021 Jeep Wrangler Unlimited Rubicon (Snazzberry)
zouch
Berkeley, CA
XJ, JLUWD
Rubi6mt
Nj
2021 JLUR 6mt
Yes, Warn wireless remote model 90287.
I have it and keep it as a back up incase a racoon jumps on my car and chews my wired remote while doing a recovery.
it's not as precise and there is a slight delay in activation compared to the wired remote when hitting either the in or out switch but good for piece of mind.
I have never had to use it so I store it in my glove box with the batteries separated in a ziploc bag
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
To further what @donmontalvo said, do you really want one? Maybe the "cool" factor?
Note that you'll most likely want to keep the wired version with you in case the wireless one fails.
I use mine if my wife is behind the wheel, allows me to get a safe distance without being in the Jeep.
zouch
Berkeley, CA
XJ, JLUWD
just curious; there’s a delay compared to the wired version?
but you’ve never “had to” use the wireless version?
how would you know how they compare? haven’t met that ‘coon yet?
i use the wireless as my primary, but keep the cabled controller for *peace* of mind. (i don’t have enough mind left to spare a “piece”.)
Rubi6mt
Nj
2021 JLUR 6mt
about every 3 months I unspool the line and hook up to an anchor point to run the winch. figure it can't hurt to run the motor and circulate the lube when the gears rotate.
playing around I tried the wireless, there is a discernable delay when hitting either in or out and the winch reacting vs the wired remote is instant.
let's put it this way. when I hit a gnarly piece of trail that I think I'll need to winch I set the jeep up with the wired remote, even though it takes a bit more time to tuck the wire in the front driver fender crease, wrap around my mirror base and then into the cabin lol.
just prefer how the winch reacts to the wired version better.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Any delay is a bit disconcerting, especially when you're nearly done putting it all back in and your fingers are getting closer to that danger area.
Rubi6mt
Nj
2021 JLUR 6mt
literally one of the reasons why I prefer the wired version as well.
TheRaven
Reading, Pennsylvania
Sold
The Mopar Warn Winch is just a Zeon 8 in a different enclosure so whatever works with the Zeon 8 will work with the Mopar version.
