Unseated Upper Control Arm Bushing
fdFifty
Pittsburgh
2022 Jeep Wrangler Rubicon
Was under the Jeep today checking things over and came across this. Doesn’t look right to me. Can anyone running stock upper control arms see if their bushing is like this on the axle housing side? I’d think it needs to be pressed all the way up to the flange but could be wrong.
Jeep Wrangler JL Unseated Upper Control Arm Bushing F5E81B2D-5D85-4206-A4A6-36AB50C490DA
EngenZerO
Ozzie
Denver, CO
2019 Jeep Wrangler Moab
Mine looks like that but I got a chirp coming from that side of the Jeep. Do you have any sounds when hitting bumps and such?
Jeep Wrangler JL Unseated Upper Control Arm Bushing 5BA6A63C-6705-4D79-B138-DC0DDC60F95A
Roky
Roky
For whatever reason, that’s how they are.
fdFifty
fdFifty
Pittsburgh
Yeah I'm chasing what I'm now thinking is a drivetrain knock and came across this. Did a google image search deep dive and saw that all the bushings appear to be this way. Kind of a crazy design because it doesn't look like it would allow much flexibility with that flange pressed up against the control arm.
Moregone
Phoenix, AZ
JLUR
Is there any silver or shiny metal in the area? Does the other side appear the same?
It looks normalish to me. I did have an issue on my old WJ when pressing in the bushing, it got tweaked a little and then straightened out. Well over time it came loose and I found it by spotting the shiny metal from it rubbing. Took it to a local offroad shop and they welded in place for me.
Ridgeline
Andrew
Irvine, CA
2021 Nacho Mojave
Just wanted to log in and thank OP and all responders for this thread. I'm chasing down a knock in my suspension and saw the exact same thing. Spent the last two days thinking that was the problem. Glad to know this is normal, but now need to keep searching.... :like:
MOJAVEC22
Miguel
Las Vegas
2020 Gladiator Mojave, 1991 Toyota Hilux
Electrician
Any idea what the chirp was? I got a squeak/creak/chirp over tiny bumps on my gladiator after i did an AEV 2" spacer lift. Also coming from the front driver side. Funny cuz it doesnt happen over big bumps or at higher speeds. Mainly slower smaller bumps/cracks in the road. Ive heard it could be the fox shocks but i hoped it was the spring on the poly spacer. sprayed silicone spray and not much better.
maaark
Cohoes NY
2018 Wrangler JLU Sport S
Electrical Engineer
Did you figure out what this was? I am currently having this issue and it's not cool.
Hercules
Clearwater, FL
2012 Ram 2500 Longhorn, 2022 JLURD
I just found this old thread- have the same odd busing look when I was under my jeep today. I had a quick panic moment, then came in here. From what I hear this is a normal look. I shook everything down there, all bolts, arms, and links are tight, nothing loose. I have Clayton Giro joints for my control arms, everything has been great thus far.
MOJAVEC22
Miguel
Las Vegas
Electrician
Sorry for the super late reply, just checking this forum as, I’m always on the gladiator forum. It still chirps here and there. I believe its either of these two things. 1. The fox shock itself, it’s not leaking and seems fine, but I never pulled it because it’s so minimal I just ignored it after a while. Now I’m leaning towards culprit 2. Slanted springs. I didn’t recenter the axle with an adjustable track bar after the 2” aev lift. Wasn’t a must with only 2 inches. So you can visually see the springs pulling towards the passenger side on the bottom. Maybe that little bit of sideways pressure. It’s been riding great otherwise.
ak47ok47
Brandon
2018 Jeep Wrangler JLU, 1993 Ford F150 4x2 5.0 AOD
Greetings!
2018 JLU Sport/lift 2.5”/fox 2.0 shocks/ 35” toyo opencountry R/T / 18” method race wheels
I am currently chasing this squeak/creak under my jeep. Has anyone had any solutions?
I had to replace the upper shock bushing on the driver side due it basically disintegrating, but other than that no issues besides mentioned above.
Jeep Wrangler JL Unseated Upper Control Arm Bushing IMG_1092
