Understanding Aux Switch - Wiring Situation
SRJeepin
Stefan
Indianapolis
2025 JL Rubicon 2-Dr.
Unbundled the wiring under the dash for the 4 auxilary switches to wire in my GMRS. When I chose the noted wire for Aux 3, orange w/ pink, it wouldn't work. Even after programming on the screen to be battery on. And grounded correctly. But I did get it to work wired to one of the red wires, and on Aux 3. Can anyone explain why the wire specific for Aux 3 didn't work?
Jeep Wrangler JL Understanding Aux Switch - Wiring Situation IMG_4448
dapipp
NW Idaho
2006 TJ, 2006 LJ, 2019 JLR, 2024 JLUR
Check your fuses, you may have popped one while messing around with the wiring, red is from battery and is always hot.
YGBSM392
Kevin
Oklahoma City
2025 Rubicon 392, 2024 2-Door Rubicon X, 2024 Mojave X
I fly da plane...
Here ya go!
Jeep Wrangler JL Understanding Aux Switch - Wiring Situation AUX Wire Colorcodes
YGBSM392
Kevin
Oklahoma City
I fly da plane...
Oh, and sorry but I feel obligated to post this:
Jeep Wrangler JL Understanding Aux Switch - Wiring Situation 94629035 copy
SRJeepin
SRJeepin
Stefan
Indianapolis
Here ya go!
If you'll see in my photo, I have two small wires that are all red. I do have the two 40A wires, green w/pink & beige w/pink. And the two 15A wires that are orange w/pink & dark blue w/pink. The other two wires are smaller gauge, like the 15A wires, and solid red. So.... it's a bit confusing since I used a red wire and ground to get AUX 3 to work. :/
Terrymo
Terry
2023 JLURXR 3.6 ET
There’s also an aux wire bundle under the hood about midway down the fender line on the passenger side. I’d be curious to know the colors on those wires since they correspond to Aux 1-4 but do not include the battery positive or ignition positive. It wouldn’t surprise me if Jeep changed the wiring colors. I used a multimeter to double check the wiring just to be sure.
jadmt
jeff
montana
my orange/pink and pink/orange looked the same to me lol, I wanted my gmrs to be on with the ignition and it was trial and error..
Jeep Wrangler JL Understanding Aux Switch - Wiring Situation IMG_9908
gatorboy
florida
Gladiator Mojave
Yep, don't blindly trust those pictures (like I did).
To confuse you more,or if you or anyone has had the Aux Switch harness installed later(not from factory) the wires will be this. Note the difference of amps to wires. Just FYI
Jeep Wrangler JL Understanding Aux Switch - Wiring Situation IMG_3518
