Zandcwhite
- Zach
- Sep 4, 2019
- Patterson, ca
- 2019 jlur
Even the manual says 1 minute from highway speed. Unless your garage is on pit row, you've got that 1 minute covered in nearly every scenario I can envision short of pulling over on the side of the freeway (which nobody should do outside an emergency).This is not needed at all. The Turbo cooling pump continues to work after the vehicle is shutdown on it is on, if needed.
Drive your jeep hard and park right away in the garage, shut it off, go outside behind passenger front tire and you will hear that pump going for a few minutes. If you drive mildly, it is. not needed and doesn't come on.
This is not the 1970s anymore, evey manufacturer has learned how to keep turbos cool. Even Jeep.
