Trickle Charger?
SadRobot
Los Angeles
2025 Prius LE
Good job. when they retrofitted that house and removed the candleholders and put in electricity when offroad vehicles were horse drawn, they used cotton covered wire.
I would avoid putting terminals under clamping bolts/nuts. Your battery terminals have places to attach terminals. Use those instead.
Why is putting on the clamping nuts not good?
The little charger terminals are made from soft material, likely copper and zinc plated. When you put them under the clamping nut, it squashes and spreads them more and more each time you clamp the battery terminal. Eventually, the little terminal hole gets bigger and bigger. As always, I'm sharing this because I was stupid and the advancement of mankind (and womenkind) is based on what stupid people learned and pass along, so the next person doesn't do the same thing. Jus sayin.
And finally, your battery terminals have places on them dedicated for attaching this kind of stuff.
SadRobot
Los Angeles
2025 Prius LE
Makes sense.
Also your previous post about my house now has me thinking about what it looked like back in 1922 and now I'm down a rabbit hole to try and find historical photos. So thanks for that. 😂
Makes sense.
When you wire that charger, run the wires up along the battery cables, so you can remove the cables and battery without having to undo the charger wires. Avoid the temptation to run those wires like shown in your picture.
SadRobot
Los Angeles
2025 Prius LE
I read that 5 times and I guess I need a picture because I can't figure out what exactly you mean.
Don't I want to disconnect the wires? When I go to the drive the Jeep would I not just disconnect here and coil up the end of the cable and just leave the charger at home?
Jeep Wrangler JL Trickle Charger? IMG_1107
au176
WNY
2021 Islander, 2020 Newmar Ventana, 2014 HD Road King
Tired again
In the NOCO pic, imagine using zip ties to attach the Noco wires to the battery cables. Basically so they run together...
au176
WNY
Tired again
Mine sorta runs that way, but I wanted to store the NOCO quick-disconnect between the battery and the inner fender with an RVi Towed charger.
Jeep Wrangler JL Trickle Charger? IMG_0163 Larg
Jeep Wrangler JL Trickle Charger? oh the humanity
shagles
Skylar
2020 JLU Sahara
adult toy engineer
He's saying for the part you just ordered from amazon that will stay attached in the jeep, do like this so if you have to take the clamps off the battery, the noco adapter part doesn't make it harder
Jeep Wrangler JL Trickle Charger? 1772219116460-9f
SadRobot
Los Angeles
2025 Prius LE
Ah so just avoid crossing the battery. Well sadly that ship has sailed. There is one negative cable that I couldn’t fit around the battery.
Jeep Wrangler JL Trickle Charger? IMG_1106
I’m picturing you looking like this with your compulsion for neatness triggered
Jeep Wrangler JL Trickle Charger? {filename}
You say that, but you haven't seen my garage.
