Trailer 7-Pin connection
gm920
Gary
San Diego County Mountains
2019 Jeep Wrangler JLUR Billet Silver
Aircraft Maintenance Technician (Retired)
This shouldn't be that difficult, you don't need an adapter. You need to sort out the trailer wiring, do you have a multi-meter or a battery powered test light? You say the curt tester shows all is good with the JLU. If your 7/4 pin connector is like mine on my 2019 the 7 pin receptacle is rotated 90 degrees to the left i.e key-way facing left not on top. I would verify that Pin 1 (ground) is in the proper location on the Jeep and the trailer.
Jeep Wrangler JL Trailer 7-Pin connection 7-Way-RV-Diagram
Fgonzal2
Frank
Albuquerque
2022 Wrangler 4XE High Altitude
I agree it shouldn’t be this difficult. The JLU should be plug and play just like the GMC but that’s not the case. The trailer has a 6 round, the JLU has a 7 pin so yes an adapter is necessary. Look at the pictures I posted it will show what I’m working with. And you’re correct when I connect the 7 pin to the JLU it is rotated 90 degrees clockwise.
gm920
Gary
OK sorry, in the beginning it sounded like the trailer had a 7 pin connector.
gm920
Gary
I know it's not your trailer, but why a 6 round? does it have brakes or backup lights? Or just the standard stop/turn and tail?
Fgonzal2
Frank
Albuquerque
I believe it came with the 6 round. It does not have brakes or back up lights so just standard stop/turn.
gm920
Gary
garyji
Gary
Western NC
It's "on-the-ball" right? Ground or not, I've seen many not work unless it is grounded solidly on the ball/hitch.
G.
gm920
Gary
Converting it to a 4 flat would make it much simpler if everyone else that uses it was agreeable
Fgonzal2
Frank
Albuquerque
G.
I’ve tried it both on the ball/hitch and off but no luck.
Fgonzal2
Frank
Albuquerque
I was hoping there was a 6 round to the 4 flat adapter but I was unable to find anything.
Fgonzal2
Frank
Albuquerque
There are adapters that go from 7 pin on the jeep to 6 pin on the trailer.
Yes, I currently have that adapter. I just purchased a 4 flat to 7 blade to test if it works with the 4 flat.
azjl#3
North AZ
Your "utility trailer" had a 7 pin connector on it and not a 4 pin connector?
Also... it is not unusual for a guy/gal to plug in the 7 pin in incorrectly into the JL's female 7 pin receptacle... Yup.
Watch closely closely next time you try to connect that 7 pin. Good chance error on your part.
I wouyld think maybe trailer is wired wrong as well, I'd use a 4 pin for utility.
gm920
Gary
The connector on the factory tow package has a 4 flat built in
