Trailer 7-Pin connection
Fgonzal2
Frank
Albuquerque
2022 Wrangler 4XE High Altitude
Hello,
I have a 2022 4xe HA with the factory trailer tow and heavy duty electrical group package. I tried to tow a utility trailer this past weekend but when I connected the 7-pin none of the lights worked on the trailer. The same trailer connected to my fathers 2021 GMC Sierra the lights work just fine. I purchased a Curt 7-pin tester and everything is working fine on the JLU. Any ideas why the trailer works on the GMC and not the JLU? Appreciate help in advance!
JL ME
JOHN
Portage Wi
2021 JL Willys ,2006 Roadking , 2008 Hayabusa
Industrial Maintenance
check the fuse for the trailer plug on your jeep.
Fgonzal2
Frank
Albuquerque
Can you kindly advise what fuse is for the trailer? If the fuse were blown would it work with the tester?
JL ME
JOHN
Portage Wi
Under the hood passenger side. Cover of the fuse box will tell you the location of the fuse in the fuse box.
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
Hello,
@Fgonzal2
Do try to connect that same "utility trailer" using the 4 pin connector on your 2022 JL. Post back the result of doing that.
Fgonzal2
Frank
Albuquerque
@Fgonzal2
That is a great recommendation. I’ll purchase the adapter and let you know how that goes.
Rhinebeck01
Retired at 55 ..
Your "utility trailer" had a 7 pin connector on it and not a 4 pin connector?
Also... it is not unusual for a guy/gal to plug in the 7 pin in incorrectly into the JL's female 7 pin receptacle... Yup.
Watch closely closely next time you try to connect that 7 pin. Good chance error on your part.
Fgonzal2
Frank
Albuquerque
Correct, the utility trailer has a 7 pin connector so I’ll need an adapter to use the 4 pin.
Isn’t there only one way the 7 pin will fit into the slot? There is a “groove” in the 7 pin and only way it will go in is to align them. In my case I had to rotate the 7 pin on the trailer 90 degrees clockwise.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Double check that you got the plug pushed all the way in.
Rhinebeck01
Retired at 55 ..
Just watch when you plug in the 7 pin... Yes, It can be plugged in incorrectly... Also, plug in firmly.
Again, there is a chance you had it inserted wrong.. It happens..
Fgonzal2
Frank
Albuquerque
Just watch when you plug in the 7 pin... It can and will plug in incorrectly... Also, plug in firmly.
Again, there is a chance you had it in wrong..
Roger that. I’ll try it once again to make sure it was correct. Do you still recommend I try with a 4 pin adapter?
gm920
Gary
San Diego County Mountains
2019 Jeep Wrangler JLUR Billet Silver
Aircraft Maintenance Technician (Retired)
I would suspect that the trailer 7 pin connector is not wired correctly
Rhinebeck01
Retired at 55 ..
I myself think it is prudent to have in your "trailering bag" an adapter.... Also, have on your smartphone, info in regard to each fuse in the PDC related to the tow package.
With that said, do try an adapter but I do think you probably just has the 7 pin male plugged into the female on the JL incorrectly. It happens..
Fgonzal2
Frank
Albuquerque
I myself thing it is prudent to have in your "trailering bag" an adapter.... Also, have on your smartphone, info in regard to each fuse in the PDC related to the tow package.
This is my first vehicle with a towing receiver so I’ll make sure I purchase the adapter. I will double check to make sure I had it seated correctly. Will post back once I verify. Appreicate the help!
