Torque Specs + Transfer Case DIY help please!
dopestoinfinity
DW
2021 Willys
Hey folks, definitely tried the search function and the specs I came across can't be right (48 ft-lbs) for these on my JLUD? My digital torque wrench is showing about 20 ft-lbs on these currently and they are SNUG.
Also wondering, I'm going down this rabbit hole before changing the TC fluid, can I get away with leaving this skid plate on if I have my funnel / pan game in order? The drain & fill plugs both have a green line marker, should I try and re-align or try and get the torque wrench in there?
Thanks in advance!
Jeep Wrangler JL Torque Specs + Transfer Case DIY help please! Torque Specs
BDinTX
Dallas, Tx
Apologies in advance - I probably won't be of much help beyond bumping the thread.
When I did my TC drain/refill I had already swapped to a belly pan so can't help with the torque specs.
I recall my TC also had the paint pen marks on the plugs but for some reason I wasn't able to get a torque wrench in there so all I could do was line them up. It should be fairly easy to get the skid out of the way, and I doubt the few minutes you save leaving it on would be worth it.
WannFly
Priyo
Atlanta
2021 Rubicon 4Xe, 2026 MOAB
Cyber security
you can drain and refill without removing the skid. use some kitchen AL foil to create a catch basin of sorts or use something like create-a-funnel.
About the T-Case skid bolts, mine looks a little diff than yours, at least in the service manual and those bolts that goes on the cross member have a spec of 15 ft-lbs. the other side that goes to frame is spec-ed to 55 ft-lbs
Drain/Fill plug should be torqued to -
Drain/Fill Plug28 N·m (21 Ft. Lbs.)
I recently removed the fill plug to top off the T-Case, I reached 21 ft-lb before the green mark would align, so I left it there.
this is based off the torque specs on 392 that I am looking at.
LARSONEM
Eric
Eaton Rapids, MI
2022 Jeep Wrangler Rubicon XR Unlimited, 2021 Jeep Willys 2 door
I did the same aluminum foil trick on top of the skid plate too. Just wrap it around a small block of wood on the front side of the skid plate so it creates a slope to the drain pan on the back side. So much easier than dropping the skid plate.
dopestoinfinity
dopestoinfinity
DW
2021 Willys
Thanks, I got one of those flexible funnels I'm hoping that'll do the trick!
Did you use a torque wrench for the drain/fill bolts and if so did you use an extension or were you able to fit it in there?
LARSONEM
Eric
Eaton Rapids, MI
I did not use a torque wrench. Just snugged it up real good.
WannFly
Priyo
Atlanta
Cyber security
OP, get some thread sealant on the plugs and make a new mark with another color pen if you are not matching the factory mark, that way you can visually tell if its coming off.
If you have a small torque wrench, its easy to torque it as well, you will likely need a small extension
dopestoinfinity
dopestoinfinity
DW
2021 Willys
Thanks! That was the plan, I really don't want to FW the skid plate so I'm hoping I can make it work with my larger digital torque wrench and an extension
WannFly
Priyo
Atlanta
Cyber security
I have used a large torque wrench as well, its very minimal torque, should not be a problem.
If you want to buy something new, get this ;)
Jeep Wrangler JL Torque Specs + Transfer Case DIY help please! 1780688035548-ix
WannFly
Priyo
Atlanta
Cyber security
