I need firewall help...please!
rickinAZ
Rick
Phoenix
2026 MOAB 392
I'm planning out my DIYer Bank's Derringer install. As many of you know, I'm more of an aspirational mechanic than a truly competent one. The engine bay stuff seems straight-forward, as does the behind the dash work. The only thing that has me perplexed is getting through the firewall. I can see the traditional entry point, the 2" black plastic circular piece covering a hole, but it looks impossible to access in the Ecodiesel engine bay. There is also the through the fender/door jam appoach, but that won't look very tidy. Thoughts?
Guys, you've never let me down before. help please!
For those that plan to tackle this, here are two how-to videos:
The 1st vdeo shows the firewall portion at the 8:00 minute mark, but their camera angle makes it look way more accessible than it looks to me.
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
It may look hard to get to, the 2" feed-thru everyone uses, but if you take the drivers fender liner out, you can access it very easily.
MCJA
Matthew
Olympia, WA
2020 Wrangler Unlimited Rubicon EcoDiesel
@chevymitchell is correct - pretty easy to get to if you remove the fender liner. That said, you can reach it from under the dash too. It's a bit of an exercise, but it's doable.
Also, if you use that firewall pass-through, I highly recommend getting a firewall boot. The one linked below fits perfectly into the hole you're planning to use, and it can be used for wire bundles between 3/8" and 1" in diameter. Pretty handy.
https://smile.amazon.com/gp/product/B004K2285E/
rickinAZ
rickinAZ
Rick
Phoenix
2026 MOAB 392
@MCJA, The hole looks like its bigger than the grommet: 2" vs 1.25". I poked at the black circular cover with a long screwdriver and the edges felt rubbery. Do i have the right one? It's behind the windshield washer tank.
Maybe when I pull the 2" cover off it's covering a smaller hole?
MCJA
Matthew
Olympia, WA
Correct - the plug has a flange that makes it appear bigger than the hole. If you look at that plug from inside the cabin under the dash, you'll get a better idea of how big the hole is.
thance
New Jersey
2010 Commander, 2002 Liberty, Looking for JLURD
That's the one. It's got a verticle strip across the center that i was able to grab with a pair of pliers to pull it out. No need to remove the inner fender in my case. But i tend to come from the camp off remove as little as possible... your mileage may vary. I did just order the boot as my wife has complained about the draft at Highway speeds with it open and i have yet to notch and reinsert the original plug.
