Derringer install: help please!!!
rickinAZ
Rick
Phoenix
2026 MOAB 392
I removed my Derringer last year before having my DPF replaced. The dealer "suggested" that I do it to avoid putting him in a bad position with Jeep. I've procrastinated on the reinstall because the plugs for the MAS and the FRP are intimidatingly hard to access - the FRP, especially, is a real bitch. Has anyone come up with any tricks, such as removing some extraneous parts that are blocking the sensors? The install is incredibly quick/straightforward except accessing those two sensors.
I know a whole bunch of us have installed Derringers. I'm looking for a "why didn't I think of that?" suggestion.
toolaide4fit
Tom
Waxahachie, Texas
2020 JLURD
IT Director
So, I wish there was a way to make it easier. I put the hood up against the windshield, climb up on the bumper and then use a 2 in piece of foam to kneel on. Then I remove the turbo air cooler and move it out of the way. I take out the charge pipe out going into the turbo. Map sensor is a piece of cake. (next time I go in I am going to replace the Map sensor). FRP is still a pain. But, taking it off the first time I broke the tab the connector locks on to. bought a new FRP sensor to replace it, but forgot where I put it. I haven't had any install issues.
Unfortunately, the Derringer gets an error all the time while driving, but still functions. I get an !D-ERR. lost communications with Derringer.
Good luck!
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
I'm just brain storming here friend. Do you think clearing all of the codes with a scanner be an option?
toolaide4fit
Tom
Waxahachie, Texas
2020 JLURD
IT Director
Not getting any engine codes at all. I have cleared them just to be sure. Took the black cap off...didn't do anything. Contacted Banks and they are going to call on Monday. worked great for a couple years and then all of a sudden started this non-sense. More to come!
thance
New Jersey
2010 Commander, 2002 Liberty, Looking for JLURD
I have gotten replacement cables from banks for similar issues
thance
New Jersey
Regarding the original question, don't have a good answer, i have actually found it easier to reach around the turbo pipes as opposed to removing them. When removing/installing the elbow that goes into the turbo it's really easy to lose the bolts. I usually stand on a crate at the right fender to get in there. I have also broken the locking clip on the FRP cable but it hasn't caused any issues, knock on wood. Try to avoid installing/removing in the cold as the clips can get brittle.
