Those with Bank's Derringer...
rickinAZ
Rick
Phoenix
2026 MOAB 392
Do you remove the entire install before you take it to the dealer for recalls/warranty repair?
TheMike
Anchorage, AK
Red 2021 JLURD "The Big D"
Supervisor, Air Traffic Control. RETIRED at 51 baby!!!
No. Just unplug and tuck away the OBD plug. It will now be running stock.
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
What kind of recall/warranty work are you having done? If it's anything under the hood around the engine wiring harnesses, a competent mechanic will see it and know what it is. Anything involving just the OBD port for software should be just fine when the Banks cable is unplugged and tucked up.
garykk
Gary
Southern NM
2022 JLURD
Does not Jeep have the ability to tell if an unauthorized program was used on the engine? I know GM scans before any work.
TheMike
Anchorage, AK
There's nothing written or "programmed" as you say. Disconnect and it's stock. zero trace anything was there other than physical seeing the unit(s) installed if still there.
MCJA
Matthew
Olympia, WA
2020 Wrangler Unlimited Rubicon EcoDiesel
Luckily, we don't have any of those where I live.
