Torn Front CV Boot - 2024 392 Rubicon
dajuicejml
Justin
North Carolina
2024 JLRU 392
Does anyone have any experience with repair/replacement on a front drivers CV Boot? I was getting my tires rotated and the shop pointed out a hole in my Boot. Looks fairly recent as the grease appears to be fresh. I'm hearing that the Boot itself is not available, rather you have to order the entire shaft. Local shop said they were told the part was on national backorder with no eta. I was trying my best to avoid my local dealer even though it is still under warranty, but I did take it by and am waiting to hear back regarding part availability.
Jeep Wrangler JL Torn Front CV Boot - 2024 392 Rubicon IMG_0695
Sportacus
Stephan
Empire
Wrangler JLU
I have the same issue. I saw Napa sells a boot cover but only in Canada. Its ridiculous to have to buy a whole new axle for a boot!
with all the wranglers having cv joints now hopefully aftermarket solutions will start popping up.
Gorpf
‘21-392, AEV-JL370
Retired/Caregiver
Yeah. It can happen from just a rock getting stuck there, or from a slip of a tool. To match the boot on the other side, an OEM axle shaft is required, unfortunately(at least it was a year and a half ago). Should be covered under warranty. I’d contact multiple dealerships to see if there is any variance for an ETA. There’s always the RCV but then you’re spending money out of pocket.
TheGrendel
Austin
JKU Recon
I’m out of warranty. So when it happens, it will be out of my pocket regardless.
Sportacus
Stephan
Empire
Wrangler JLU
Those rcvs are expensive. If i can hold off till black friday that would help.
im running the fad so i believe id need to get the 2 piece version. Something to keep in mind if you plan to add a fad to your 392.
Sportacus
Stephan
Empire
Wrangler JLU
If anyone is replacing their stock cvs with rcv and want to sell their stockers at a reasonable price shoot me a pm
TheGrendel
Austin
JKU Recon
you don't have to get the 2 piece version. but, personally, I would if you already have the actual FAD.
