Topsy Lift thread
STLYoungblood
St. Louis, MO
2018 Wrangler JLU Sport S Ocean Blue
This may not be the correct place to ask, but in every picture I have seen in this thread, the Racor is mounted so the center beam runs parallel with the Jeep. In my garage the rafters run parallel with my Jeep, so if I mounted directly to the rafters my center beam would be perpendicular to the Jeep. Is there any reason that I can not / should not do this?
I don't know if that would matter. If you're using the topsy lift though, the hooks connect to the sides of the rack that have the actual bars and not just the wire rack, so you'd need to position that correctly. You could always run a couple 2x's and lag into that though
slimgrady18
Minnesota
I'll run some 2x's if necessary, just trying not to make extra work for myself. Thanks for the response.
Movingday
Murfreesboro, TN
2018 JL Sahara
Isn’t the platform a 4x4 square? So you should be able to orient it however needed regardless of how you install the hoist
JLUSoCal
IT
Jeep Wrangler JL Topsy Lift thread 20180603_175348
The only downside I have with rafters that are perpendicular to the garage door (same as you needed to mount so "gearing mechanism that lifts the platform" is in the front or could be back of the jeep). The problem with that is I can't lift it off the jeep as easy as if the gearbox was on the side. When I first installed the Racor I didn't have the Topsy so it was a manual lift of the hard top drag to below the racor to lift. Now I might do a 180 turn of the lift to put the gearbox back by the tail glass, we'll see. As noted the platform works either way as the attachments to the cable are "square" so that's not a problem. Ultimately I didn't have room on the side where I park the Jeep so it sits above the hood of my Camry.
My original setup before the topsy was to pull the rack and use 2x6 wood under the back of the hard top and superstrut for the front. Both of those "platforms" were connected to the cables using the existing eye bolts. The wood I just drilled into the 2x6 that stuck out 6" on either side. The superstrut I bought some 90 degree angle pieces with holes on both sides to thread the cable through the superstrut and attached about a foot in to the 90 degree angle. That helped so I did NOT need to adjust the cable lengths when I went from platform with softtop on it OR hardtop no platform attached to the platforms that supported under the top. I didn't have room to open the back glass because of a header beam about 6" from the back of the rack and with the garage door up I literally have a few inches of room before the door would hit the top of my 8' rafters. If that all makes sense. But since I bought the topsy (not available when I masterminded above) and looking to swap where the gearbox sits.
Shots
Winchell
Ohio
'22 Rubicon
Excellent. A ball park estimate is close enough. I just wanted to start dialing it in from somewhere close to the balance point, and that should do it. Thanks.
JLUSoCal
IT
Red vs. Yellow - gearbox safety latch....
I bought my Racor from a liquidator warehouse in LA. My lift has a yellow safety latch and I think I've seen red in most of the pictures. Is there any difference and did they improve the red gearboxes OR is it just they started painting red? I think the weak link is the cable holder being made of plastic but not sure if the gearboxes changed?
Shooting or Jeeping
2020 JLUR, 2019 RAV4
I’ve seen both ways, so you should be fine. Just be sure that you realize the back is not the same as the front in terms of removing the top. Having the support beam across the back allows you to slide the straps to compensate for this a little easier. But if you run it the other way, you just need to make sure that you attach the straps to the corners of the support to get the best stability.
Shooting or Jeeping
I can’t speak for the color difference, but I can tell you that Topsy is starting to make a replacement for the plastic cable holder. Check out their site. Simple fix.
Movingday
Murfreesboro, TN
2018 JL Sahara
Put my racor together last night, plan on install this weekend. Any advice for doing it by myself?
mdelzer
Grand Rapids, MI
www.undercontrollabs.com
2018 JULR Sting-Gray
Developer, Home Automation and AV
Doesn't matter. I put mine on the side so that I have easier access to crank it up and down.
Ok, I was alone, so the measurements from front to back and front side to side aren't perfect, but they're pretty close:
Hinge Bracket to Bracket: 34 3/8 ish
Front Top Side to Side: 59"
Front to back: 95"
Hope that helps!
95" seems long, if you are going off of the points where the racor lifts, since the lift is 4x4 square. I would recommend if you are doing a custom hidden lift that you go with lift points as close to the C pillar of the top as possible because it should be more ridged.
STLYoungblood
St. Louis, MO
Oh shit, you're right, I measured to the freedom panels! I'll remeasure in a bit.
STLYoungblood
St. Louis, MO
Updated:
Front to back: 66"
Now, as far as where the straps come out on the sides, you get some play there. The racor platform is about 4x4, so 48-50" is probably a safe bet. I'm going to yank the top off today, so I'll be able to measure exact if you like.
ajester1272
Andy
NW Arkansas
2018 Sting Gray JLUR
Updated:
Front to back: 66"
Thank you so much - if you can confirm when you take your top off, great! If not, no biggie. Definitely gives me a good point to start.
STLYoungblood
St. Louis, MO
It’s about 50” spacing since the Topsy brackets stick off back
