To Catch a Catch Can
QwikKotaTx
Houston, TX
2015 Hemi Ram, 2002 Porsche 911 Turbo
I was just curious. I did the UPR because I like the location a little better but debated the Mishimoto. I was skeptic of catch cans until I installed one and did some research on direct/port injection, carbon buildup, cleaning fuel systems... etc.
Does the UPR can block oil filter access? From the pictures it looks like you at least have to remove the bottom portion of the can to access. The can on my Ram has a valve at the bottom which makes draining it easier than unscrewing the lower portion. This setup does not look like that would have room or access for adding a valve to the base.
AU_JLU
Australia
JLU Sport S
Why do we only install one catch can on one of the pcv lines? The 3.6 has two pcv lines. One off the back of each bank and one feeds in before the throttle body and one after. Both lines have oil residue in them. Adding a catch can to only one like all the kits of the market is only half doing to the job?
