Thoughts about winches
Willys53
mark
commiefornia
1951 Willys CJ3A, all original, 1953 Willys CJ3B with V8 and mods , 2021 JLUR Diesel
I think steel vs synthetic is just a personal choice. I have been using steel for 30 years on my Jeeps and trucks and have never had a failure. I use winches quite often around the ranch as well as off road . I have pulled stuck tractors, other jeepers , trees and even a garage onto a trailer Enjoy what you pic and it will be fine I chose steel again ( cant teach old dog.....)
steelerpsugirl
steelerpsugirl
Maryland
2018 Wrangler Unlimited JL Sport S
steelerpsugirl
steelerpsugirl
Maryland
Winch is going on hopefully this morning so will post pics! Still determining if I will swap for a synthetic rope (harbor freight just sent a 10% off everything of course so I’m going to see what that would look like for a rope and hawse fairlead). Thanks everyone!
HungryHound
TN & FL
1975 CJ-5, 1983 CJ-5, 1998 TJ, 2021 JLURe
I was just going to post the harbor freight sale. You beat me to it ?
HungryHound
TN & FL
While we're talking winches I actually got a good piece if advice from a salesman at a dealership. If you opted for the aux switch package, you can use one button for winch in and one for winch out. Unless, of course, you're adding ridiculous amounts of lights, then you'll need those buttons.
HungryHound
TN & FL
Make sure you have a fuse on the hot side near the battery. I wouldn't worry too much about 1 loop on the ground side. Too many loops will create an antenna which could screw with your electronics under heavy load.
spenat
nat
manhattan beach
2019 sting grey JLUR
how does one wire their aux switches up this way?
HungryHound
TN & FL
Pull the wires in from the hand held plug-in remote and separate the wires based on function. Takes a little work and maybe a few blown fuses, but it's easy after a few beers.
steelerpsugirl
steelerpsugirl
Maryland
curious about wiring to the battery, that’s the step we stopped on. Which wire goes where?! The video we were watching provided zero help!
HungryHound
TN & FL
Red wire goes through a fuse to the + side of the battery. Black wire goes to - side of battery.
