Zandcwhite
- Zach
- Sep 4, 2019
- Patterson, ca
- 2019 jlur
An 18 gauge wire will melt the installation at well under 100A. Good thing I didn't wire my winch in 18 gauge. Also, my engine Bay isn't carpet lined so we should be good there. Pretty sure the turbo and exhaust manifolds get hot enough to ignite carpet every time I drive. A front impact severe enough to damage my winch cables would push the winch/bumper through the radiator and bend the hell out of the frame, pretty sure that's more damage than my deductible. The 2 Guage wires would likely discharge the battery bellow their limit long before they'd catch fire. The battery is only capable of ~700A when fully charged and falls off quickly under heavy load. Run a fuse if you'd like, but again I'm pretty sure warn would suggest it if it was a major concern? Who knows, maybe you have more winch knowledge, experience, and expertise than they do...The winch option on the new JL/JT has a fuseable link from the factory. I've seen a little 18 gauge wire completely burn the insulation off and melt carpet in the trunk of a car on 2 seconds. Most vehicle fires are electrical. I'm putting a fuse on mine since the winch is in the front where impact from a wreck is most likely. If the fuse blows while I'm winching, I have a $4 spare. If that blows, then I'll bypass it while winching then disconnect it before driving home. Do what you are comfortable with, but in my case, a $30 fuse block and fuse is cheaper than my insurance deductible.
